Constant beeping noise coming from instrument cluster | FerrariChat
Discussion in '360/430' started by enzoferrari, Jun 1, 2024.
  1. enzoferrari
    enzoferrari Rookie
    Jun 7, 2006
    49
    Would love to get some thoughts on this. 2007 F430 F1 - started the car this morning and there was this constant beeping noise coming from behind the instrument cluster. It would stop when I put the car in Reverse but would come on when I am in neutral or in gear.
    No warning lights. Dis-connected the battery and let it sit and the sound comes back. It even is on when I turn off the car with the key out of the ignition.
    Any ideas?
  2. Qavion
    Qavion F1 World Champ
    14,100
    Ian Riddell
  3. hessank
    hessank Formula 3
    1,904
    Canada, Florida
    Fred
    With so many reports "I've got the same sound coming from my dash', the biggest problem is that no one has come back to educate the rest of us on the root cause or solution. Or did I miss it?
  4. enzoferrari
    enzoferrari Rookie
    Jun 7, 2006
    49
    Hey Fred,
    From what I found it seems it has happened to quite a number of folks but you are right no one has reported back on what it was or how the issue was resolved. I am guessing it has something to do with the instrument cluster - I will be sending the car to a professional to diagnose and hopefully fix. I will report back what I find.
    oc23 and hessank like this.
  5. enzoferrari
    enzoferrari Rookie
    Jun 7, 2006
    49
    Thanks Ian I did read that thread but no real answers as no-one on that thread reported back on a fix or cause
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,793
    Central NJ
    Dominick
    @enzoferrari You can try to Direct Message (PM) a few of the people that had it and hopefully they are still on here and will give you an answer
    enzoferrari likes this.
  7. oc23
    oc23 Formula Junior
    433
    Rob Yo
    Does it sound like a faint turn signal is always on? Just a faint click, click, click...
  8. anotherred360
    anotherred360 Formula Junior
    Jan 10, 2015
    278
    The thread linked earlier says it's a capacitor and/or other components on the instrument panel circuit board. If it's a bad capacitor you might be able to identify it with a visual inspection.
