Contemporary track prep for a Daytona? | FerrariChat
Discussion in 'Tracking & Driver Education' started by ersatzS2, Nov 8, 2009.
  1. ersatzS2
    ersatzS2 Formula Junior
    Jan 24, 2009
    862
    Norfolk VA
    I'm shopping for a Daytona, and when I find one I've gotta take it a least once or twice to the track.
    Has anyone tracked one recently who could give some feedback on preparation?
    I've heard they don't have great brakes but wonder if that was a legacy of 1970's pads; do contemporary pads work better? How about cooling? (to the brakes I mean) Any other track issues? I'd use stock Michelins, seatbelts, etc, and I'll drive at spirited DE speeds, but I'd like to know whether it's realistic to get in full 20 minute sessions or not without major work...
  2. judge4re
    judge4re F1 World Champ
    Apr 26, 2003
    13,477
    Never home
    Dr. Dumb Ass
    Give Mike Sheehan a call, ask him if he has 10 minutes.
  3. fatbillybob
    Aug 10, 2002
    29,026
    socal
    I think it depends on how good a driver you are. You need to be good enough to not do stupid things and ask the car to do things it can't do. You need to be good enough to work the brakes and heat up the engine and drive train for that matter. In general modern pads are amazing relative to what we had in the 70's and cooling brakes helps an undergunned brake do its job. Then again what are you willing to modify to get a good sized duct of cool air to the brakes? Also, picking the ambient temp you track at means alot too. Running Oct-Mar. makes a huge difference vs. May-sept.. You could use some tempilaq from pagasus autoracing supply.com and find out the hot temps you run the brakes at the track and that will tell you scientifically if ducting cool air will help you or if it is a waste of time for the conditions at hand.
    http://www.pegasusautoracing.com/productselection.asp?Product=3161
  4. solofast
    solofast Formula 3
    Oct 8, 2007
    1,773
    Indianapolis
    Also depends a lot on what tires you are using. More modern tires have faster cornering speeds and but more load on the brakes. Probably also need to lose the wire wheels (if so equipped) and this is particularly true if you are using modern (ie sticky) tires.
  5. BIGHORN
    BIGHORN In Memoriam
    Sep 18, 2006
    733
    FLORIDA/NEW MEXICO
    JOHN F KELLY
    +1 on the wire wheels. Also watch out for oversteer; Daytonas turn in with a light to moderate push and go to loose real fast.
    Also lightly apply the brakes on the straight after a few laps to make sure they are still working.
    The main problem with the brakes is fluid boiling, so the Ducting advice above is good
  6. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    i have one current customer who runs his Daytona regularly on track. He brought the car 1 year old and has had it since, he is getting up in age but drives it relatively hard.
    Other than the usual 'fluids and safety' twice a year, I rebuilt the shocks all around. The wheels are wires, fitted with a later Dunlop street tire. The brakes run a slight upgrade on the pads with a higher temp fluid.
    If it were to get more /harder useage, I would increase the ducting as well as a different pad material. This car runs a racing 20W50 oil in the engine, water wetter additive and Royal Purple gearlube with good temps when run in FL.
    HTH, Brian
  7. aja
    aja Karting
    Jun 6, 2005
    172
    pepper pike,oh
    adam adelstein
    For upgradded brake pads i would take a look at Carbotech performance brakes. They do alot of vintage race cars. http://www.ctbrakes.com/
  8. CRPracing
    CRPracing Rookie
    Nov 9, 2009
    2
    Charlotte, NC
    Nicholas Short
    What shocks does he run on his Daytona Brian?
  9. ersatzS2
    Jan 24, 2009
    862
    Norfolk VA
    thanks for all the thoughts. I'm in dialog w/Michael regarding prospective cars so yes I'll ask him. Also I figured it'd need alloy wheels. This must be one of the highest HP/torque street cars ever to wear wires which by 1970 had sure outlasted their original design brief.
    The rotors look smallish and I'm guessing they are going to get hot quickly.
    The reminder about time of year is a good point.
  10. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    Nick, car is all stock, the Koni shocks were rebuilt in CA by ProShocks I seem to remember. I also replaced all the bushings and spring rubbers, then a good alignment.
  11. Telerding
    Telerding Formula Junior
    Sep 30, 2004
    362
    Santa Maria/CA
    Tom Elerding
    Brian:
    For alignment, did you go with the stock settings F&R?
  12. BigTex
    79,386
    Houston, Texas
    Bubba
    Tspringer had a nicely set up Daytona, he took me for a Track ride in it.....
  13. oceans
    oceans Karting
    Jan 3, 2008
    155
    Jacksonville, FL
    Rob
    I took my Daytona to five track events. Bob Grossman and Harley Cluxton drove their Daytona to 12th overall at Sebring with the windows up the A/C on and the tape deck playing Beethoven.
    All of the advice above is good, just don't overdrive your brakes. Get used to modern cars wanting to get by. Breaking the transaxle was always my biggest fear. Honestly, all I ever did was check the fluids and fill it up with gas.
  14. DM18
    DM18 F1 Rookie
    Apr 29, 2005
    4,725
    Hong Kong
    I had my daytona on the full F1 track at Shanghai. I have AP Racing front calipers - aside from that stock. I have my positraction shims set relatively tight - car grinds around slow speed corners but comes onto its' own on high speed sweepers. I had no issues. Brakes were fine for 20 minute session.
