Control Arm Removal Process | FerrariChat
Discussion in '308/328' started by wildcat326, Aug 12, 2015.
  1. wildcat326
    wildcat326 Formula 3
    Dec 10, 2012
    1,803
    Chicago, IL
    Justin
    This may seem like a stupid question, but can you just pull A-arms, or do you have to take off the shocks, rotor, or half-shafts, etc.?
    More importantly, IF you have to remove the peripherals, in what order?
    My control arms need new bushings and powdercoating, and I remember reading that you can damage the CV boot flanges if the axle just droops down unsupported, so I want to make sure I dismantle properly. Thanks.
  2. 308nut
    308nut Formula 3
    Jul 22, 2002
    1,881
    NOLA/Covington
    Wade
    yes you need to remove everything, shocks, sway bar, hub, brakes, etc. don't forget to take note of the spacers, not only the ones for the ball joints on the front end but the lower control arms hangars have spacers as well. the order can be a little different for whomever is removing the parts but usually
    rear - rotors, brakes, backing plates,half shafts, hubs, sway bars, lower arms, upper arms
    front - rotors, brakes, backing plates, tie rods,ball joints, shocks, lower arms, upper arms.
    and the bushings all have a spot weld on them to secure to the control arms,
    when reassembling do not lockdown the arms, set the car on it wheels and let sit for a few days then lock them down or your ride height will be off.
    we just finished the suspension on a 76 GTB if you would like some pics of the process send me your email
    Wade
  3. Owens84QV
    Owens84QV F1 Rookie
    Oct 2, 2001
    4,486
    Somewhere in NC
    Greg
    Very important. Shims and spacers everywhere. Not to scare you...just take note of where they are so it goes back together as it came off.
    Once you start the disassembly process, it becomes obvious what needs to come off first, then second, etc.
  4. wildcat326
    Dec 10, 2012
    1,803
    Chicago, IL
    Justin
    Dammit, messing with the brakes is the LAST thing I wanted to work on. My arms need restoration and bushings, but really I just wanted to pull them to get the fuel tanks and maybe front header out. I'm working on the fuel system and exhaust rebuild at the moment, and wanted to repaint the tanks and ceramic coat the headers. Only way I could think of for getting reasonable access without pulling the motor.
    How do the hub and rotor come out? Isn't there another specialized ring nut in there somewhere?
  5. cmt6891
    cmt6891 Formula 3
    Feb 25, 2008
    1,340
    Encino, Ca
    Carl T
    The brake caliper spacers are probably the most important of the bunch to make sure they are replaced correctly. They are not all the same thickness so make sure of which ones are place where or you will have issue with caliper alignment with the rotor.
  6. Basal Skull
    Basal Skull Formula Junior
    Oct 26, 2010
    427
    Vancouver BC
    #6 Basal Skull, Aug 12, 2015
  7. mikepama90
    mikepama90 Rookie
    May 12, 2014
    2
    I think technically you don't have to remove much, everything is pretty simple like a normal car. the only tedious part is just keeping track of the spacers between the caliper and hub.
  8. krismik
    krismik Rookie
    Aug 21, 2013
    7
    Germany, north
    #8 krismik, Aug 14, 2015
  9. ClydeM
    ClydeM F1 World Champ
    12,118
    Wayne, NJ
    Clyde E. McMurdy
    Not that I want to argue, but I just pulled mine to replace the front shock bushings on both sides.
    I did disconnect the caliper, but I probably didn't have to.
    rotor & such all stayed together.
