Control arm shim position? | FerrariChat
Discussion in '308/328' started by Austin Newman, Jan 23, 2022.
  1. Austin Newman
    Austin Newman Karting
    Dec 18, 2019
    229
    Memphis
    Austin Newman
    Doing a full suspension tear down and took plenty of pictures for reference. However i am curious if the shims in place are there to adjust the imperfections of the car or are they suspension adjustment tools? Essentially is there a default/ neutral amount i should reset too? Will the alignment correct things as well?
  2. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I guess the answer is both? Yes, there are shims that are either inserted/removed, or moved from one side to the other to get all of the alignment angles in spec.
  3. dhalter
    dhalter Karting
    Aug 2, 2009
    130
    New York
    Darryl
    I am doing a complete suspension rebuild now as well, and also took copious notes to keep track of all the stuff. Lot of stuff to keep track of. Are you going rubber or poly bushings?
  4. ProvaMo
    ProvaMo Formula Junior
    Jun 29, 2004
    347
    Mid West
    Paul John
    The front oblong shims, between the front upper & lower ball joints and the upper & lower control arms (see pic, with a hole at either end, approximately 24mm wide by 76mm long and 26mm wide by 71mm long) are to adjust Caster Angle, there are 16 total (four for each front ball joint, mix on each side adjust Caster). The large U-shaped shims (between the frame and lower control are mounts) are for all Camber, front Kingpin Inclination and rear toe. Corrections welcome!
    Saabguy likes this.
  5. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,139
    SanFrancisco BayArea
    1983 US 308 GTS QV
    +1 regarding the notion that these shims can be used to adjust caster. Whether they are intended for that purpose is an open question since they are so difficult to readjust because disassembly is so difficult.
    On my car, the position of the shims is different left versus right side but this puts my caster within 0.1 degrees of each side.
    Within the bounds of adjustability, caster is probably the least critical suspension alignment specification.
    ProvaMo likes this.
  6. Austin Newman
    Dec 18, 2019
    229
    Memphis
    Austin Newman
    Is there a factory default setup?
  7. ProvaMo
    Jun 29, 2004
    347
    Mid West
    Paul John
    If there's a factory default, it would be starting with 2 shims in each position (which I may start with based on a full rebuild)
    See pics: My 1979 USA GTS had two on each side of both the front upper ball joints. On the right front lower ball joint, three shims in the rearward ball joint to lower control arm position, with one on the front side. On the left front lower ball joint, three shims on the front side, and one on the rear side... hope this helps.
  8. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,797
    Cerritos, CA.
    And here was my original set up. When I changed to the new ball joints, I put it back the same way
    Top = left side
    Bottom = right side
  9. Rifledriver
    36,938
    For once someone has it right.
  10. Rifledriver
    36,938
    According to Ferrari the ball joint shims are used for caster, not the control arm shims.
  11. Rifledriver
    36,938
    Only insofar as the upper inner shims are concerned. It is shown in the parts book.
