Control Stalk Installation | FerrariChat
Discussion in 'Mondial' started by wilkrod, May 13, 2024.
  1. wilkrod
    wilkrod Karting Silver Subscribed
    May 9, 2012
    243
    Ocala, Fl
    Hi All,
    So I removed the light, wiper, and turn signal stalk from the hub of my 83 QV for some repairs. I am finding reinstall to be quite difficult due to the spring and ball in the end of each stalk.
    If anyone has any tips on the reinstall of the stalks I would appreciate it.
    Many thanks
    Regards
    Jeff
  2. Alden
    Alden F1 Rookie Rossa Subscribed
    Apr 25, 2010
    3,596
    Central Florida
    If you have the right spring and the right ball, the end of the stalk should simply slip right over them, you may have to slightly depress the ball to get it started, but it's not a difficult thing to do, I think you may have some incorrect parts or missing parts.
    I seem to remember a thread here that dealt with getting the proper size spring and ball as a replacement since the owners originals were missing, see if you can search for it.
    I think they ended up using a ballpoint pen spring and a ball the size of a BB.
    Also, it's good advice to do this operation with the end of the stalk in a plastic bag. So if the ball and or spring come flying out you won't lose them.
    Alden
  3. Rifledriver
    37,072
    Its much easier if the entire switch is on the bench. I have never even considered disassembling it while installed.
  4. wilkrod
    May 9, 2012
    243
    Ocala, Fl
  5. wilkrod
    May 9, 2012
    243
    Ocala, Fl
    85QVEuro likes this.
  6. Alden
    Apr 25, 2010
    3,596
    Central Florida
    Like Brian said I would definitely do that on the bench not in situ. I thought you were just talking about getting the ends of the stalks back on.
    Alden
  7. Rifledriver
    37,072
    I use safety wire but zip tie would work quite well too. Install stalk then cut and remove the ties.
