430 - Conversion F1 relay wiring confusion | FerrariChat
430 Conversion F1 relay wiring confusion
Discussion in '360/430' started by flash32, Jul 19, 2025 at 12:03 PM.
  1. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,895
    Central NJ
    Dominick
    Hello everyone
    Maybe the conversion gurus like @modificator etc can help me here
    As most of you know I help a number of people with their 360's and 430's especially when it comes to F1 system including the E-diff etc. I have come across a few that have had their cars converted to a manual but left the e-diff functional ( solid decision imho). I needed to trace some wiring the other day to diag a issue and saw that the the f1 pump relay trigger terminals (84, 85) were wired to 9a and 12a of E-diff ecu. The factory manuals are wired to 12a and 5b ( 5b is solid ground). SO.....the question is why ? I have a few inquiries out including those I helped to give me a few mins with a multimeter etc to see if I can figure it out. All the documentation on E-diff ecu pinouts do not even speak to pin 9a. What is 9a ? - i know it provides ground to the relay but not sure why a undocumented pin ( at least from f430 Manual WSM) was chosen vs 5b
    If someone has a broken ECU that can be taken apart to look at - that would also work
    Please help me help others
    Dominick
  2. imahorse
    imahorse F1 Rookie
    4,338
    WI
    Dustin
  3. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,895
    Central NJ
    Dominick
    Asked already..doesn't know other than what is specificed in conversion specs
  4. modificator
    modificator Formula Junior
    437
    Florida
    George
    Hi Dominick, 9a works well for me and I have not given it a second thought, maybe there are multiple ground pins.
    flash32 and Qavion like this.
  5. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,895
    Central NJ
    Dominick
    Thanks George -- yes ...it definitely works and works perfectly - it is just me not understanding why one pin was chosen over the factory manual one
    This is only for an education ( mine mostly) .. not to fix any issue with a conversion or pin assignment during a conversion
    Thanks again
    modificator likes this.
  6. Qavion
    Qavion F1 World Champ
    14,262
    Ian Riddell
    Neater wiring? Doesn't it look more professional than, say, splicing into good wires.. and possibly compromising those?
    flash32 likes this.
  7. Qavion
    14,262
    Ian Riddell
