Conversion of F1 transmission to manual. | FerrariChat
Discussion in 'Technical Q&A' started by open roads, Nov 16, 2013.
  1. open roads
    open roads F1 Rookie
    Jan 28, 2007
    3,799
    Sarasota, Fl.
    Stan
    Hello tofisi. I did a search here and found nothing.
    I have a desire to see if an F1 can be converted. It makes sense that it can be because there is an F1 actuator that selects the gears. The gears are as they would be in a manual, the box being in essence an automatically operated manual I believe.
    I can imagine that there would be the inevitable issues. There always are.
    My interest is this.
    I have a Boxer race car project. I do not know where I want to go with it yet. I do not want to kill a street car. My preference is to bring back the dead. In this pursuit, I will be horribly upside down if remaining faithfully BB. There is an alternative in TR parts.
    But as I look at architecture and arrangements, many ideas pass through my mind ir I wish to stray away from an all BB route.
    The higher center of gravity has made me think of alternatives. A BB in front of a tranny is one.
    Moving the bulkhead a bit forward could provide a couple more inches. I will not change the body lines or the wheel location.
  2. DanNE
    DanNE Formula Junior
    Jun 7, 2013
    713
    So if you're doing a BB and contemplating TR parts what's the F1 connection, I don't get it...are you looking to use a F355 and newer style actuator on a BB or TR gearbox?
    FYI - there has been recent activity in the 360 forum on a conversion between F1 to manual; supposedly 'easy' to do as parts bolt right on.
  3. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    A lot of expensive parts to change. Probably would only make sense if you had a parts car to remove them from.
  4. open roads
    Jan 28, 2007
    3,799
    Sarasota, Fl.
    Stan
    Thank you for letting me know. I remember seeing that thread title now. But I did not read the thread when I saw it.
    I was in a hurry earlier, running out the door.
    And I just realized that the 360 and 430 would be the obvious place to look, because they have both available.
    I am simply discovering possibilities right now. If I go to a silhouette, well it's not much BB. It may be a BB only in looks.
    A TR is an easy swap IMO. It is an updated unit of the same architecture. So that route make a Boxerossa.
    I was just wandering if it would be possible for me to use a transaxle unit behind a flat 12. There was an F1 car of about 1970 that did something like that.
    I would want to take stuff "off the shelf" and modify it maybe. If it were possible to do such a thing, the length of the packaged block and tranny will become a factor in the tight confines of a BB. The firewall in a BB could be moved forward a little in a track car. There is also wasted space, or rather space that could be used differently in a reinvisioned BB, with a true period look outside, a boxer bock, maybe even tranny. But a different mechanical architecture inside. Again, TR suspensions are easier to find than BBs. This would result in a pure exercise of wanting to do the different, and ending up with a track day car. It would be ineligible, so probably not favorable. But I have this curiosity.
    I was looking at transaxles that might work. I came upon the 458 box. But, alas, I would want a three petal car. So it becomes more than merging two housings and drive shafts.
    I'll look for that 360 thread. That may provide an easy solution if I am crazy enough to go this route. And I may be.
    If you look at my avatar, that is about where I am. I want a good idea of where I want to go with it. That's why I'm looking around.
    From where I am, there are many places I might go. Some of which are not where many would go.
    For me, this is just like playing with a puzzle. I have an inquisitive mind and I like to roll things around a bit. And I'm trying to find a focus before I step off.
    I think that the 1978 IMSA car of the Pozzi team, the #88 car, is available in Europe. When I am flush I will try to pick it up. So my tribute effort, the #89 car of that year may be still born. Or it may be the Boxerossa stablemate of #88. I just don't know myself at this point.
    But I do thank you for your help. And I do love seeing BBLMs on track. They have always been heroic to me.
  5. open roads
    Jan 28, 2007
    3,799
    Sarasota, Fl.
    Stan
    #5 open roads, Nov 16, 2013
    Yes. The easiest route of all is to buy a totaled TR. It is straight forward then.
    The result is a Boxerossa. I don't mind too much. I am waiting for one to show itself. I could even use the frame and shorten it.
    I started with the idea that I would buy the frame from the burned (BB)car at T Rutlands. They have the salvage title. That I would have as a badge of honor.
    And it would be a BB. Back from the dead.
    It is just a question of how far under water do I really want to be. And where do you start cutting corners.
    I am thinking that I might have a BB frame, driveline, instrumentation and title. I am considering a custom or TR suspension and steering rack. This, to me, is a reasonably acceptable modded BB.
    Cutting all the corners makes a TR that is clothed as a BB. I think there is one around. Oh no. There is a BB that was repowered w TR. Someone even said put an M unit in one.
  6. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Who said anything about a TR or a Boxer? Your question appeared to be regarding converting an F1 car to manual (355, 360 or 430).
    The Boxer and TR are quite different cars. Adapting a transaxle from something else (360 or 458) would require significant re-engineering.
    What's your end objective?
    How huge is your budget?
    All of this would certainly be ultimately much more expensive than a nice, original car. These kind of projects always are.
  7. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    #7 Crowndog, Nov 16, 2013
    I know a guy that has a few flat twelve OEM engines sitting in his garage. Also happens to be a boxer man.
  8. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,910
    Richmond
    Pete
    If you're creative, you may be able to get a transverse gearbox out of a 348 or 355 to fit in line with the flat 12 as they are more compact than the 360/430 units and put the axles just behind the engine. You'd have to move the flat 12 4" or so, not sure there's enough room for that.
  9. open roads
    Jan 28, 2007
    3,799
    Sarasota, Fl.
    Stan
    I think I may know him as well. There can't be that many.
    Hey Crowndog, I'm coming up to Washington County as I always do. I'll PM you and see if we can get together to compare notes.
  10. open roads
    Jan 28, 2007
    3,799
    Sarasota, Fl.
    Stan
    This is where I was coming from. The F1 tie in was because it looks as though the most compact is the 458 unit.
    If possible, it will be tight.
    And this is just a feasibility study. The end goal not having been determined. There are no doubt easier ways to do this. But I would want the flat 12, or I won't consider it further.
    What I was thinking is this.
    1) Minimize the longitudinal distance of the obvious drastic change. That is the mating of the engine/clutch housing, to the transaxle in the shortest amount of space.
    2) See if after gaining as much space as possible by moving the firewall forward, the unit fits.
    This is probably best accomplished on a cocktail napkin than with a cutting torch and welder.
    There is that little space where the filters and pumps are. Then there is all that plumbing and accessories on the front of the block. Lots of reworking. Not even to be considered unless the unit itself could fit. If so, then the other stuff comes into consideration.
    Again, this is a feasibility study. The point of the F1 change is because there may be a desire to do this to a 458 Tranny. It appears to be the most compact.
    There also is the odd chance that a TR tranny might work. Wouldn't that be interesting if so.
  11. open roads
    Jan 28, 2007
    3,799
    Sarasota, Fl.
    Stan
    Mods. Could you please change the name of this thread to "Alternative drivetrain for a Boxer, Flat 12".
  12. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,910
    Richmond
    Pete
    That's why I suggest the transverse box from a 348 or 355 (or mondial T) as the flywheel/clutch are on the end, not in between the engine and trans so the drive axles are closer to the engine. I think that may be the most compact for your purpose and there's no need to convert from f1
    The 458 trans is a dual clutch auto, no way to convert that to manual unless you 'fake it' with a stick shift that has sensors on it and just pass the shifts to the trans.
  13. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Can't wait, please give me a shout
  14. 410SA
    410SA F1 Veteran
    Nov 2, 2003
    8,511
    West Coast
    A
    Why?
    If you really want a manual transmission car, go and buy one that was engineered that way, rather than trying to create a Frankenstein
  15. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Making the parts fit in the car would be the relatively easy part. The programming necessary to get a bunch of mis-matched stuff to work together would be a leviathan task.
  16. tbakowsky
    Sep 18, 2002
    20,019
    The Cold North
    Tom
    I'm not realty understanding what you want to do here. Do you want to have a bb with f1 shifting, or do you want to adapted a 355 f1 gearbox to a bb..
  17. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,910
    Richmond
    Pete
    I think he wants a BB with flat 12 that doesn't sit on top of the transmission so the CoG is lower. Hence suggestion of one of the transverse boxes that put the clutch at the back and keep the axles closer to the engine. I still don't think it'd fit with stock wheelbase and without modifying the firewall, but maybe.
  18. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    YIKES....my brain hurts. I am completely lost with the topic stated and the chat goin on
  19. tazandjan
    39,294
    Bruce- Never did figure out what F1 had to do with anything mentioned.
  20. open roads
    Jan 28, 2007
    3,799
    Sarasota, Fl.
    Stan
    Bingo !
    Just maybe.
    I do like the idea of a lower Cg and closer to the middle too.
    Again. Just thinkin. Without spendin.
  21. open roads
    Jan 28, 2007
    3,799
    Sarasota, Fl.
    Stan
    Several people have mentioned a percieved disconnect with the conversion of an F1.
    I concur. This is more about an alternative, albiet, only, is it possible, powertrain.
    Hence, my request of the mods to rename this thread, in the name of accuracy and the desire for others, who in the future, may research this.
    A better titled thread may read like this.... Alternative power train for a Boxer or even a Testarossa.
  22. open roads
    Jan 28, 2007
    3,799
    Sarasota, Fl.
    Stan
    Hey,
    If you can get it in the back of that thing in my avatar, that is a miracle in itself.
  23. vrsurgeon
    vrsurgeon F1 World Champ
    16,584
    Charleston, SC
    Curt
    I would go with the 355 tranny personally, it retains the transverse configuration. With the 360 tranny, you're going longitudinal which is going to add length and with the block on the 12 I wonder if you'll cut too much into the cabin with the spacing from the axles.. You'll def have to get some measurements and some pics. What I would do for the mating is machine mating plate. If its too big, then machine 4 aluminum plates that intersect that bolt up.
    458 would be cool, but might be spensive' as you'd need the dsg controller CPU, and shifting levers and wiring harnesses. It also wouldn't be a stick. It's too bad you won't go with a 360 or 430 8 cyl engine. You could blow it or use it stock, more power and lighter weight. Throw the whole engine-tranny unit in and race it...
