355 - Convertible Top Control Module Repair | Page 2 | FerrariChat
355 Convertible Top Control Module Repair
Discussion in '348/355' started by DanRC30, Feb 10, 2025.
  1. Qavion
    Qavion F1 World Champ
    14,594
    Ian Riddell
    Ah, you mean the lower number on the relay. I don't know if that is significant or not. It may just be a batch number or date code.
  2. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    I wish there was a way to find out. I don't even know where to begin looking for these answers....
  3. Qavion
    14,594
    Ian Riddell
  4. m.stojanovic
    m.stojanovic F1 Rookie
    3,303
    Serbia - Niš
    Miroljub Stojanovic
    Tyco bough over the Siemens Electromechanical Components division so the former Siemens relays are now Tyco. The important number on the relay is only the V23081-C1061-A303. You can just buy the relays from the Chinese seller on Ebay because they are made in the large Tyco factory in Suzhou. And if you buy them from a US seller, or even from an official Tyco dealer, they will most likely be also from China.
    PS: I often remember the comment in the movie Armagedon: "American components, Russian components, all made in Taiwan".
    DanRC30 and Qavion like this.
  5. m.stojanovic
    3,303
    Serbia - Niš
    Miroljub Stojanovic
    DanRC30 likes this.
  6. Qavion
    14,594
    Ian Riddell
    Get in quick before the China tariffs are applied ;) The price may go up by 2 or 3 dollars.
    DanRC30 and Mike Morrissey like this.
  7. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    Is there a way to test the relay to see if it's good or bad before I remove it from the board?
  8. m.stojanovic
    3,303
    Serbia - Niš
    Miroljub Stojanovic
    Not really, you would need to unsolder and remove it. There are actually two relays in the box and, to test them, you need to connect 12V supply to their coils which, if done in-situ, is likely to damage the electronics to which the relay coils are connected. Ohming the relay coils may give you some indication but it will not be conclusive, again due to electronics connected to the relay coils.
    DanRC30 likes this.
  9. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    #34 DanRC30, Feb 11, 2025
    I figured as much.
    Do you agree with the tech that this is the issue? Are you aware of a moderate or high failure rate of these? I did find a company that's supposedly working on a rebuild service, but it doesn't seem to be ready yet...waiting to hear back from them. https://www.ecudoctors.com/products/ferrari-f355-spyder-br-convertible-top-control-unit
    I also found this: https://www.facebook.com/reel/1218235779232868 - https://www.autotronics.co.uk/product/ferrari-355-spider-roof-control-module-repair
    This tells me that there are issues with these units. Just looking to confirm my suspicions here and that the relays can and do fail before I go and try to repair it myself.
  10. m.stojanovic
    3,303
    Serbia - Niš
    Miroljub Stojanovic
    I am unable to comment on the probability of relay failure as I did not have or work on a 355 and my 348 was a hard top.
    DanRC30 likes this.
  11. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    Well, that's fair. lol! Hoping someone who has experienced the same thing will chime in...
  12. jjtjr
    jjtjr Formula Junior
    Aug 29, 2016
    763
    Vermont
    john truskowski
    I can tell you that the potentiometers that are under the seats can be problematic, just do a search here. They read seat position and send a resistance reading to the convertible top ECU. Let us know what fixes your issue when complete, a lot of threads go dead when the OP moves on without posting what the actual solution was. Thank you! :)
  13. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    My problem is the driver's seat working intermittently as far as moving forward. It moves backward just fine, but not always forward. I don't think that has anything to do with the potentiometers.
    I took the unit out to the car and hooked it up while it was removed from its housing and tested the system. I wanted to see if I could actually feel the relays click. It seems that the one relay is not clicking when trying to make the seat go forward. But then all the sudden it did actually work and the seat went forward. And then it stopped working again. I think I'm going to take a chance and just swap out that relay and see what happens.
  14. Qavion
    14,594
    Ian Riddell
    Not sure, but I think the potentiometers only come into play when the roof switch is being used. I guess you could disconnect the plug on the pot to prove this. I thought the pots may affect the limit of seat movement when using the seat switches, but I didn't test that theory, mainly because the previous owner of my car didn't use an SD1 tool to calibrate the seat movement, so it may not have factory settings.
    Does your roof switch move the seat forward? If it does, then the seat switch or the relay isn't the issue.
  15. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    Is the roof switch supposed to move the seats forward? I never tried it.... Haven't really tried anything since I bought it a few weeks ago. Waiting for the scheduled major service in April.
  16. Qavion
    14,594
    Ian Riddell
    Yes, if you satisfy the roof operating logic.
    In preparation, lower the sunvisors to prevent damage to the leather on them, unlatch the roof (observe the windows drop a few centimeters). If the windows don't drop, don't operate the seat button. I forget if the doors have to be closed or not.
    Handbrake on, car running. Pull back the roof manually until you hear a single beep (if it beeps continuously, you have other issues).
    Operate the roof switch (backwards). Both seats should move forward simultaneously. If you have long legs, be prepared to have them squashed around your ears :p
  17. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    lol! But the roof is currently down... what should I do?
  18. Qavion
    14,594
    Ian Riddell
    Put it back up? This should be an interesting logic test.
    Handbrake on, engine running. Push the roof button forwards. The seats should move forwards unless they are already (almost) fully forward. The windows should drop if they have been manually fully raised.
    I don't suppose you know how high your roof hydraulic levels are?
  19. Qavion
    14,594
    Ian Riddell
    Note that all kinds of things could go wrong during roof raising, especially if the roof hasn't been operated for a while. e.g. The hooks behind the seats may not engage with the pins on both sides, leading to roof bending and the conical pins which mate with the windscreen frame may not engage.
    My roof has a tendency to slam down hard on the window frame. Be prepared for this.
  20. Qavion
    14,594
    Ian Riddell
    P.S. Since you've removed the upright section of the centre console, now would be a good time to check your roof fluid levels.
    In theory, if only one seat moves forward, the roof shouldn't work. If the roof does start moving with only one seat forward, stop roof operation immediately.
  21. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    Since I didn't know the process of raising or lowering the roof, I wasn't sure if raising was different than lowering. I really don't know how to operate the car yet. I planned on learning after I get the service done, but it looks like I'm starting to learn a little earlier than expected. Lol
    Where is the fluid reservoir located?
  22. Portofino
    Portofino Formula Junior
    Sep 17, 2011
    944
    Yorkshire UK / Switzerland/ Antibes France
    Portofino
    My 348 spider has what appears like a 1960 Alfa Romeo s pram hood , simple as a wheel barrow going forwards in time . Hoods not even lined with hidden elastics which inevitably snap .
    355 spider electro hydraulic hood was parts lifted off the then current Merc SL ….turned out to be a dreadful system multiple hydraulic fluid leaks , air into systems , micro switches going bad and this same “ control box “ issues .
    They weren’t to know .
    Luca MM ( by 1995 ) was on a mission to make Ferraris more useable , open to a wider market , add more comfort like this roof and power steering , making the chassis “Micky mouse driver proof “ on the limit , sport and comfort switchable damping amongst other mods so your auntie Mable could go shopping in it especially if a F1 box in “auto “
  23. Qavion
    14,594
    Ian Riddell
    Under the pump.
    Where's the pump?
    See the semi-transparent fluid reservoir with the level markings on it.
  24. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    Ok, so I plugged the module back in and then the seat switch worked. Then it didn't. Then it went forward a little bit, then didn't. It'd work and then not without any indicator as to why. So I hit top up button and the top started to move, but neither seat moved when I hit the switch. I didn't want to push it because the driver's seat was back, but the pass seat was forward. I left the pump console cover off and it looks like there's a sensor on the side of that piece that goes up against the driver's seat. I'm GUESSING it wasn't "reading" the seat so the top was OK to go up. Plus, the seat only seemed to go up a little bit and stop every time. Maybe because of the sensor not being there? I didn't let the top go up because obviously it would've hit the seat. ALSO, once I hit the top up button, both power seats wouldn't operate at all by the switches until I removed the key and turned it on again. Oh, and I did this with the key in the ON position, not with the car running. I don't want to run it because it has a big coolant leak that needs to be addressed, and I haven't run the car to check the oil level.
  25. Qavion
    14,594
    Ian Riddell
    Interesting. I wonder if the driver's seat potentiometer (position sensor) is indicating that the seat is almost fully forward (i.e. it's broken or missing). This is on the seat rail under the seat.
    Que? I think I'll need a photo of that.
