355 - Convertible Top Control Module Repair | Page 4 | FerrariChat
355 Convertible Top Control Module Repair
Discussion in '348/355' started by DanRC30, Feb 10, 2025.
  1. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    I think I need to pull the seat to tell what's what. But I can see two wires (blue/bk, white/bk) bypass that trailer connector. They go under the seat to a little black connector. I have no idea what those orange and white wires are doing. Maybe it's some kind of resistor? See pic.
  2. Qavion
    Qavion F1 World Champ
    14,588
    Ian Riddell
    #77 Qavion, Feb 11, 2025
    No resistors. They're just jumper plugs which will stop the roof operating if disconnected.
    Blue/black & Black/white match the motor plugs in the wiring diagrams for the driver's seat.
    Sorry, I mean to say 7 wires apart from the orange wires. Your driver's wiring matches mine... except when it reaches the black tape section. The 5 wires which go to the 4 pin plug become 4 wires on your car. Sounds like you have a unique potentiometer setup. If the splicing under the black tape was done correctly, you should only need a 3 pin black plug (or standard white).
    Disconnect the black 4 pin plug and see if the seat operates.
  3. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    Well, I got brave.
  4. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    I disconnected the black connector and the seat worked perfectly. Then I reconnected it and it still worked perfectly. WTH is going on???
    Also, keep in mine every time I disconnect/reconnect that module I flip the power shutoff to the car by the CD changer in the front. Doubt that has anything to do with it but figured I'd mention it.
  5. Qavion
    14,588
    Ian Riddell
    #80 Qavion, Feb 11, 2025
    For future reference: The alphanumeric code assigned to the wires represent Roof ECU plug and pin number. The yellow wire on your car goes to the potentiometer wiper arm.
  6. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    No idea why this is like this, but I think I'd like to go back to a factory connector, if I can source one...
  7. Qavion
    14,588
    Ian Riddell
    Maybe coincidence. Did you disturb the motor wiring?
    If the potentiometer system is affecting the manual operation of the seat, I don't know how it's doing it. Look for damaged insulation/shorts. Operate the seat and shake test the wiring. Don't flatten your battery or overheat the seat motor.
  8. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    I mean I was pulling on it to see how much wire I could expose for pictures...
    I can't see the pots you're referring to. Can you see them in my pictures?
  9. Qavion
    14,588
    Ian Riddell
    The pot(entiometer) is not easy to see... Here's a photo from the earlier link I provided on how to repair the pot..
    I wouldn't bother changing the black plug. I doubt you'd be able to find an OEM replacement. It just needs to be secured somewhere on the seat. Either way, make sure that the wiring is long enough with the seat fully forward.
  10. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    Ok, at the very least I'm going to get rid of those bullet connectors and solder it. At least that will rule out a poor splice connection.
    Qavion likes this.
  11. Qavion
    14,588
    Ian Riddell
    I'm still not convinced it's a potentiometer wiring issue. I disconnected mine completely and my seats still operate.
  12. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    I think it's either a bad connection, a relay, or a weak motor issue. The drivers side motor doesn't seem as strong as the pass side, but then again, I'm usually sitting in it and that's a load on the motor. Weird how it just worked flawlessly for me. I'll go out in a little bit and try it again...
    Qavion likes this.
  13. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    Ok, so this is bananas... Seat is working perfectly now. And when I hit the top up switch, the seat will automatically go forward like was mentioned earlier in the thread. It did that several times without issues. Then I disconnect the black plug and it reverts to not pushing the seat forward and the top activates. Once the top activates, the seats will not move in any direction. It's like they're locked out. Then I turn the key off and on again and it works properly again. Then I reconnect the black plug and it acts up again activating the top and not moving the seat forward automatically. Then I cycle the key and it goes back to working. But other times it didn't work that way. Other times it would just work no matter what It's like an insane dance in the car and makes no sense. lol!!!
    So then I started playing with the plug and the splice connections while moving the seat and while triggering the top up. And I noticed that while triggering the top up, the seat would move forward correctly, but suddenly stop and the pump would activate! AH!!! I think I found my problem! I think I have a bad connection in the splices and/or that connector.
    I know you said not to swap out that connector, but I think I'm going to do it because there are crimp splices at both ends which means I need to remove the seat and solder anyway. And why not get a better, more factory looking 3 wire connector while I'm at it from the auto parts store while I'm at it? This is literally a 4 wire trailer connector and looks like crap. Do you have a picture of the factory connector? I'll try to find something similar it if I can....
  14. Qavion
    14,588
    Ian Riddell
    Just checked on my car. That's normal. After the seats move forward (with the roof switch) and the roof starts moving, the windows and seats are frozen.
    Do you mean when the seats were well forward? The forward limit for the seats in the Roof ECU should be programmed (by the Ferrari SD1 tool). Once the ECU (via the pot) sees the limit (a certain voltage/resistance), it stops the seats moving. Occasionally pots break or lose their calibration. There are techniques you can use to fudge the calibration after you repair them.
    There are some photos of the white connector here, but I can't say I've seen any replacements.
    https://www.ferrarichat.com/forum/posts/136344918/
    It has a fixture at the back to allow it to clip into the seat base.
    DanRC30 likes this.
  15. Qavion
    14,588
    Ian Riddell
    TE Connectivity make other plugs for the roof system, but I can't find any TE plugs online which match the OEM style 3 way pot connector.
    DanRC30 likes this.
  16. m.stojanovic
    m.stojanovic F1 Rookie
    3,303
    Serbia - Niš
    Miroljub Stojanovic
    #91 m.stojanovic, Feb 11, 2025
    I would certainly replace that connector, crimp the original wires directly if long enough otherwise solder extension wires and insulate the joints with heat shrink tube. The current flowing through the pot wires is very small (some mA) so you don't need a big connector. As it may be hard to find a connector similar to the factory one, I would go for a 3-pin Tyco (AMP) Superseal:
    Ebay: AMP Electrical Waterproof Connector Kit 1 2 3 4 5 6 Pin Way Super seal Car Auto | eBay (again, it comes from a Tyco factory in China). You can also search for a local source if you need to get it faster.
    DanRC30 likes this.
  17. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    What happens is as the seat moves forward and I handle the connector/splices, the seat will stop randomly and the top will function. But then I'll continue to play with it and the seat will then go forward again. It's like there's either a short or a bad connection is confusing the control unit. I'm going to remove the seat and replace the connector and that should hopefully solve the problems with the seat not moving forward 100% of the time. I'm embarrassed that someone used a trailer wiring connector on it. How ridiculous. #facepalm
  18. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    Just got myself a kit. Thx for the advice!
    https://www.amazon.com/YMYP-711Pcs-Waterproof-Automotive-Connectors/dp/B0CL9D3DDQ/ref=sr_1_1_sspa?crid=JEP0HRGFTH79&dib=eyJ2IjoiMSJ9.cpEubh5R_1SrbRLeNZbZCcwr4sFLtzTuYlH3bogaMwiDZAsWSRsTchub8yHj3Mitx0dBlm8UsTnEFij3CMQwS-abWsE9vufvHkb6igC9vAIfcS9iVWYxAEOv2EqqxqNeJDyg1bIGIPcY_ShVf8NyoLwKiqNqcNbp9qJ4Xz7sv_Rt2Cx3uwMaSCEzrdnbs5vh8MC2G4TPvF_qD-HKA509MG_Jwu3T7ddl-EHNWxA2ZsM.UAlJs4OdGSbhMiOUPAQNZi9NBr6siEf4byvf99nP5uU&dib_tag=se&keywords=waterproof%2Bauto%2Bwire%2Bconnectors&qid=1739379348&sprefix=waterproof%2Bauto%2Bwi%2Caps%2C113&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&th=1
  19. Qavion
    14,588
    Ian Riddell
    Just be aware that if you don't secure the plug on the seat, it will be dragging on the floor. The clips and projections on the plug may get snagged on the carpet.
  20. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    Yes, I'm going to find a way to clip it to the seat. What does the factory clip look like? Any pictures?
  21. Qavion
    14,588
    Ian Riddell
  22. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
  23. Qavion
    14,588
    Ian Riddell
    DanRC30 likes this.
  24. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
  25. Qavion
    14,588
    Ian Riddell
