355 - Convertible Top Control Module Repair | Page 9 | FerrariChat
355 Convertible Top Control Module Repair
Discussion in '348/355' started by DanRC30, Feb 10, 2025.
  1. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    206
    NJ
    Dan
    Update: just spoke with my friend who I bought it from and he said both seats wouldn't move forward together every time when he hit the vert switch, but sometimes they would. Sounds to me like the ECU isn't functioning properly. Thoughts?
  2. Qavion
    Qavion F1 World Champ
    14,511
    Ian Riddell
    Was he talking about the driver’s seat not moving forward?
    I’d still check the passenger pot resistance at the ECU. These things can break at any time. The pot ball and socket may not be gripping, depending on temperature and humidity.
  3. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    206
    NJ
    Dan
  4. PhilB
    PhilB Formula 3
    Feb 17, 2004
    2,355
    Southern New Jersey Shore
    Phil
    Dan - could it be simply that both seats or either seat is not all the way back, fully away from the dash and steering column?
    I'm trying to recall, but I seem to remember on my 355 if the passenger seat was positioned where it was not in the way of the top operation - in other words, if the seat wasn't all the way back, then it would not move when I operated the top. My wife always sat closer to the dash than I did to the steering wheel, so her seat (passenger side) was never in the way of the top operation and mine always was, so my (driver's) seat always moved forward when operating the top open/close switch.
  5. Qavion
    14,511
    Ian Riddell
    @DanRC30 I don’t see your point about the PO’s comments. Didn’t you find some dodgy wiring on the driver’s side which you repaired? See Feb 17th.
    Apart from driver’s seat movement limitations, the drivers’ seat operates normally. Why are you now suspecting an ECU fault? You haven’t checked the passenger pot yet.
  6. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    206
    NJ
    Dan
    So, the way it operates is you hit the top switch and both seats move fully forward so the top will operate. Right now I have two issues: 1) The driver's seat won't go as far forward as the passenger seat. 2) The pass seat won't move forward with the driver's seat when hitting the vert top button.
    But both seats work with their own switches, even though the driver seat won't go fully forward.
    Yes, I replaced the crappy trailer wiring harness connector with a waterproof sealed auto connector (3 pin).
    I think the ECU issue is causing the passenger seat not moving with the driver's seat when hitting the very top switch. I don't think that's related to the driver seat not going fully forward. I think that's a POT switch setting/calibration issue. Again, just my suspicions...
    I haven't had a chance to check the ohms on the pass side pot yet.
  7. Qavion
    14,511
    Ian Riddell
    You've said that you suspected the Roof ECU twice, and seemed to be leaning away from the passenger seat pot being faulty. I just wanted you to check the pot before you went looking at Roof ECU repair. If you're opening or closing the roof and the Roof ECU thinks the passenger seat is fully forward because of faulty pot (even though the seat isn't actually fully forward), it will shut off power to the seat motor and not move the seat forward at all.
    Simplified check: If you move the seat fully back with the seat switch and check the pot reading at the ECU and it reads high resistance between pins B-18 and D-16*, and low resistance between B-18 and B-16, you'll know that the pot is faulty.
    *also at D-5 and D-7 (because these are jumpered to D-16)
    Of course, for a full check of the pot, you'd probably need to measure the resistance at both ends of seat travel and perhaps at the mid point.
  8. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    206
    NJ
    Dan
    Didn't know this: "If you're opening or closing the roof and the Roof ECU thinks the passenger seat is fully forward because of faulty pot (even though the seat isn't actually fully forward), it will shut off power to the seat motor and not move the seat forward at all."
    HAPPY TO DO THESE TESTS!!! I'm excited actually... Do you have the diagram handy of the ECU showing which pins to test? And to confirm, I should test at the connector after pulling it off the ECU, correct?
  9. Qavion
    14,511
    Ian Riddell
    Yes. Don't test the ECU pins, test the sockets on the ECU plugs (car side)
    The sockets are shown in this diagram:
    B-18 has a black/blue wire.
    B-16 has a grey/yellow wire.
    B-16 has a black wire/s.
  10. m.stojanovic
    m.stojanovic F1 Rookie
    3,297
    Serbia - Niš
    Miroljub Stojanovic
    I would do the pot resistance checks as follows:
    1. Move both seats fully back
    2. Disconnect the plug from the roof controller
    3. Measure the resistance ground to pin B-18 (passenger's seat) and ground to pin X-?? (equivalent pin for the driver's seat)
    If you don't get similar resistances for the two, it would mean one of the pots is out of adjustment.
    If you get very big difference between the two (like closer to zero on one and closer to max on the other), the possibility is that yellow and black wires have been swapped-over on one of the pot connectors.
    DanRC30 likes this.
  11. Qavion
    14,511
    Ian Riddell
    B-19
  12. m.stojanovic
    3,297
    Serbia - Niš
    Miroljub Stojanovic
    The last line in your post #209 - I believe you mean "D-16" (the black ground wire).
    DanRC30 likes this.
  13. Qavion
    14,511
    Ian Riddell
    Ah, correct. Typo.
    DanRC30 likes this.
  14. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    206
    NJ
    Dan
    With bots seats all the way back, I set the meter to 20 and got the following:
    B-18: 2.14
    B-19: 1.23
    Qavion likes this.
  15. Qavion
    14,511
    Ian Riddell
    #215 Qavion, Mar 14, 2025
    Both seem high, especially B-18 passenger seat. Maybe you need to run the seats fully forward and re-measure.
    I'm not saying my values are correct, but here's what I got previously:
    Passenger (fully aft): 924 ohms (B-18)
    Passenger (fully fwd: 4329 ohms (B-18)
    Driver (fully aft) : 576 ohms (B-19)
    Driver (fully fwd) : 3742 ohms (B-19)
    After your fully forward, repeat the fully aft measurement to see if the values are consistent.
    My values were recorded directly at the potentiometers, but there shouldn't be too much difference at the ECU
    I've seen one aft value on the forum which was slightly above 1000 ohms.
  16. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    206
    NJ
    Dan
    Do you want me to disconnect the pot on the driver seat so it goes all the way forward, or test it with the pot connected where it stops and it's not all the way forward?
  17. Qavion
    14,511
    Ian Riddell
    If possible, both ways. That way we can establish what is the possible range and what is the actual range.
  18. Qavion
    14,511
    Ian Riddell
    I'm wondering if driving a seat to its mechanical limits will keep resetting the pot (thanks to the slip of the ball and socket). If you drive it all the way forward, will this make the seat not go back far enough (because the electronic SD1-tool limits set at the factory are limiting the range)?
    I forgot to ask my tech how the SD1 tool works.
    DanRC30 likes this.
  19. Qavion
    14,511
    Ian Riddell
    Just asked my tech about the SD1 calibration...
    It doesn't involve disconnecting the pots. You just run the seats forwards and backwards. Then the SD1 tool tells you to move the seats into a green zone (on the display).
    This still doesn't make sense to me. It doesn't explain how to move the seats fully forward and fully back (as in your situation)... unless the SD-1 tool temporarily overrides the potentiometer's effect on seat movement.
    DanRC30 likes this.
  20. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    206
    NJ
    Dan
    Seats forward with driver seat stopping short:
    B-18: 2.14
    B-19: 2.34
    Both seats all the way forward by disconnecting the POT on driver seat:
    B-18: 2.15
    B-19: 2.22
  21. Qavion
    14,511
    Ian Riddell
    Something definitely strange going on here:
    1) Driver seat value changing, but range seems limited. Did the seat actually move further with the pot disconnected?
    2) Passenger seat value not changing.
    I’m assuming the diagrams are correct (regarding pin numbers). Did you confirm pin numbers with the assistance of wire colours?
    I would first think that:
    1) the driver’s pot was positioned in the wrong position during installation. Is it possible to partially remove the seat with the seat fully aft on the rails (pot connector disconnected), then remove the case from the pot and try to adjust the potentiometer independently of seat movement so that the potentiometer reads 500~1000 ohms. Then reinstall. Or did you try this already and couldn't get enough forward movement (perhaps because of the ECU programming). Note that the seat pots seem to be non-linear, so adjusting them at the lower end of resistance may show a big difference at the forward end.... kilo ohms instead of a few ohms.
    2) the passenger seat pot has broken. The ball and socket may not be gripping.
    The forward values are all the same (and somewhat atypical). I suppose the seat pots may have been disturbed in the past.
  22. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    206
    NJ
    Dan
    Yes, the driver seat moves fully forward when disconnecting the POT.
    B-18 is black/blue
    B-19 is grey/blue
    I did not test B-16, but it is grey/yellow
    Was I supposed to check B-16? Isn't that just power to the POT?
    Yes, I can do this with the driver seat. I can put it in any position, remove it from the car, take apart the POT and rotate it until I get the correct resistance, and then reinstall. I just have to hope that the number I set it to matches the program in the ECU.
    I haven't removed the passenger seat yet due to limited space. I can probably move the car over when I sort the driver seat POT. I have a feeling the POT isn't working either, which is strange because both seats moved forward when I hit the top close button, before I messed with the driver seat.
    (BTW - Damn the person who designed these POTS with crappy plastic parts.)
    Qavion likes this.
  23. Qavion
    14,511
    Ian Riddell
    That was a typo... See Miro's correction. Resistance checks were meant to be between B-18/B-19 and D-16, but any good ground should replace D-16..... Although, testing with D-16 also checks the ground wire between the pot and the Roof ECU.
  24. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    206
    NJ
    Dan
    I used D-16 as requested. What next?
  25. Qavion
    14,511
    Ian Riddell
    ah, I see what you mean. I have resistance values for D-16 (from my car), but I have to convert them from my pot wire colours to pin numbers.
    Another thought.... I'm slightly concerned that the ECU pin resistance readings may not be the same as direct pot readings because of shared wiring between the passenger and driver's seat. With the passenger seat forward or aft and your new driver's pot plug disconnected, can you retake the passenger measurement across B-18 and D-18 and see if the value is different?
    Regarding my pot values (using pot wire colours)
    e.g. the red pot wire on my car corresponds to the black wire (D-16)
    red-black = >4kohms
    red-yellow = 924ohms
    yellow-black = 3940ohms
    Passenger (fully fwd)
    red-black = >4kohms
    red-yellow = 4329ohms
    yellow-black = 543ohms
    Driver (fully aft)
    red-black = >4kohms
    red-yellow = 576ohms
    yellow-black = 4218ohms
    Driver (fully fwd)
    red-black = >4kohms
    red-yellow = 3742ohms
    yellow-black = 1028ohms
    My ohmmeter is only designed for low resistances, so I don't get a reading above about 4.4k ohms.
    B-16 (grey/yellow) = yellow pot wire on my car.
    D-16 (black - ground) = red pot wire on my car
    B-18 (blue/black) = yellow passenger pot wire on my car (middle wire)
    B-19 (grey/blue) = yellow driver pot wire on my car (middle wire)
