convertible top issue | FerrariChat
Discussion in '348/355' started by expresscat39, Jun 10, 2007.
  1. expresscat39
    expresscat39 Karting
    Nov 6, 2005
    115
    Bonita Beach,FL
    Dennis
    Have had this 97 F355 for almost 8 years. During that time I have only put the top down 4-5 times. The top retracts back OK to where it is to "unhinge" from the support pins and start making the downward motion. The passenger side releases and is OK but the driver's side will not leave the pin. When it gets to that point it is skewed.
    Any suggestions.
  2. expresscat39
    Nov 6, 2005
    115
    Bonita Beach,FL
    Dennis
    Once I got into, it even my limited capability on a Sunday or any other day, I was able to isolate this one. The pneumatic cylinder on the driver side is weak on the downstroke but strong up the upstroke. Probably a bad cylinder. It does work some but not sufficient to disengage the hinge.
    Have to figure out how to remove the panel over the assembly to replace the cylinder.
  3. f355spider
    f355spider F1 World Champ
    18,053
    Check the fluid level first. Search for the relevant threads. Top it up, and bleed before bothering with replacement.
  4. PAP 348
    Dec 10, 2005
    100,224
    Mount Isa, Australia
    Pap
    x2! :):)
  5. expresscat39
    Nov 6, 2005
    115
    Bonita Beach,FL
    Dennis
    It's pneumatic. Maybe a loose fitting but nothing to top off.
  6. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
    Interesting.....
    I've only had my top up 4-5 times.
  7. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
  8. f355spider
    18,053
    I give up with this one...he already knows it all! ;) (pnuematic would be a first, since every other car manufacture that I am aware of uses hydraulics for automatic operation)
    It is very possible the reservoir is low on fluid, which would prevent the rams from operating correctly. Run it that way, and you will permanently damage the rams, if they aren't already. Follow the instructions provided above, and please report back. Good luck!
