430 - Convertible top replacement | FerrariChat
430 Convertible top replacement
Discussion in '360/430' started by blackbolt22, Mar 16, 2025.
  1. blackbolt22
    blackbolt22 F1 Veteran
    5,792
    Boca Raton, FL
    Mr. Anderson
    So the top for my 07 spider is in need of replacement. I got a quote from F or Ft Laud for around 8500 which includes a new headliner. Current one seems fine but it should probably be replaced as car is 17 years old. They don't do the work but it runs through their dealership. I would prefer to bypass them . That price seems a bit steep.
    I'm looking to have a local shop do it. My question: Should I replace the bands that hold the rear side sections taunt? I don't know the name of the part. I remember one of them failed many years ago and Indie mechanic replaced it. It's possible both have been replaced.
    Is there anything else that should be done or replaced while I'm at it?
    I couldn't find those bands on Eurospares diagrams. It isn't the first time I can't locate a part from their diagrams though.
    What did some of you pay to have your 360 or 430 tops replaced? I'm going to collect a few estimates.
    I'm in south Florida if someone has a recommendation. I posted in Florida section already.
  2. GogglesPisano
    GogglesPisano F1 Rookie
    2,964
    East Bay, California
    Joe
    Replace every single part that has elastic. I’ll have to look up the rear straps but I remember them being around $350 each. I was able to remake mine though for a fraction.
  3. GogglesPisano
    2,964
    Joe
    Oh, and if you don’t mind, can i have your old top after it is removed if they don’t cut it off?
  4. blackbolt22
    5,792
    Boca Raton, FL
    Mr. Anderson
    IIRC, Mercedes designed and built the roof mechanism for Ferrari. Can someone confirm?
    Also, I think the replacement top comes with all the elastics . I'm not sure about those 2 rear ones I mentioned. I don't see why not though.
  5. GogglesPisano
    2,964
    Joe
    According to the interwebs, the top mechanism was design by CTS Fahrzeug-Dachsysteme GmbH, later bought out by Magna: https://aldousvoice.com/2013/02/05/ferrari-360-spider-roof/
    The elastics are primarily located in the headliner, not the top. There are a couple on the top itself but are not removable.
    The rear straps are called the rear screen tensioner straps. #23 in the diagram: https://www.eurospares.com/Ferrari/430/F430_Spider_(USA)/PartDiagrams/0111/ROOF_CANVAS_-_SEALS_-_MOULDINGS?ref=023
    I have yet to see those included in any kit. There are also a variety of small elastics that are situated around the frame for what I can only guess are there to prevent rubbing/marking from the inside. These are attached to the frame only and not part of the top or the headliner assembly. If your installer has a good quality 1" automotive grade elastic on hand, these can be replaced easily by cutting to size.
    blackbolt22 likes this.
  6. priericky128
    priericky128 Formula Junior
    614
    St. Louis MO
    Rick
    I paid to have my top replaced in 2023 and it was $4500 with elastic strap repair included.
    i did my own cylinder repair and replaced the front rubber strip myself tho.
    top came from GAHH and was indistinguishable from oem other than the window was sewn in versus zippered I believe.
    67bmer and blackbolt22 like this.
  7. GogglesPisano
    2,964
    Joe
    It's funny, there's a replacement procedure for just the rear window but the process is so involved, it's just better to replace the entire top.
  8. priericky128
    614
    St. Louis MO
    Rick
    You mean on the oem top?
  9. GogglesPisano
    2,964
    Joe
    Correct.
    priericky128 likes this.
  10. blackbolt22
    5,792
    Boca Raton, FL
    Mr. Anderson
    I was thinking 5-6k for the job. 8500 is a bit steep.
  11. blackbolt22
    5,792
    Boca Raton, FL
    Mr. Anderson
    Thanks for your help. So the top is German made, but not Mercedes. Good info.
    I would hope a shop of almost 30 years experience would be able to sort out the elastics.
    So 2 of the rear tensioner straps are needed? It looks like one size fits all for them. Are you also saying the shop should be able to replace elastic in the tensioner straps?
  12. GogglesPisano
    2,964
    Joe
    there is a left and right. I was able to remake these for a lot less than $500 obviously using new elastic and some top material.
  13. blackbolt22
    5,792
    Boca Raton, FL
    Mr. Anderson
    I'm looking at other diagrams but don't see one for the right side.
  14. GogglesPisano
    2,964
    Joe
    Hmm. I see there isn’t a RH listed. The part is clearly listed as LH and I know they are not identical. They’re mirror images and have a slight taper.
  15. blackbolt22
    5,792
    Boca Raton, FL
    Mr. Anderson
    I emailed Eurospares.
    GogglesPisano likes this.
  16. priericky128
    614
    St. Louis MO
    Rick
    Yeah 5-6 would cover it. Also yes any convertible top specialty shop who can do this top should absolutely be able to do the elastics also. The material costs very little but there is some labor to do it.
  17. blackbolt22
    5,792
    Boca Raton, FL
    Mr. Anderson
    Do you recommend rebuilding the cylinders since I'm replacing most everything else? Where are they located?
  18. GogglesPisano
    2,964
    Joe
    If you have the down time, 100% do the cylinders. That's my only regret. I would have actually yanked the whole system out and had it redone with new seals from this place: https://tophydraulics.com/ferrari/106-2262-f430-spider-05-09-full-set.html#/30-core_exchange-send_your_parts_to_top_hydraulics_first
    If you haven't had your cylinders repaired yet, it's only a matter of time at this age and they'll never be more easy to access than when the top is off.
  19. priericky128
    614
    St. Louis MO
    Rick
    Yes I would do the cylinders. I did my cylinders first to make sure the mechanics were right and then did the top itself but doing them all together makes total sense.
    there is one in the middle of the plastic piece where the hooks engage over the front window, two above the door windows, two behind the seats on the outboard side, and two in the engine bay under the radiation shields. They are shown in the wsm I believe.
    the cylinders are shared with a few models of Mercedes products but it’s probably easier to remove them and send them off than reseal yourself. I did mine myself but I did it a few times before I got it right. If you want my notes on that lmk I have a source for seals but he is extremely slow.
  20. Cknkeyasen
    Cknkeyasen Karting
    Nov 28, 2023
    55
    Dallas
    Cliff Nkeyasen
    My 430 top replacement has been a nightmare over $8K smh
  21. dmijoskov
    dmijoskov Karting
    Oct 8, 2011
    60
    Palm City, FL
    Danny Mijoskov
    What happened?
  22. Cknkeyasen
    Cknkeyasen Karting
    Nov 28, 2023
    55
    Dallas
    Cliff Nkeyasen
    The glue would not adhere properly install took like a month. Now my windows don’t slide into rubber stripping properly so getting a lot of wind noise
    good luck with your project!!
  23. DrivnXcitment
    DrivnXcitment Karting
    Apr 29, 2006
    220
    St. Augustine, FL
    Bryan
    Also consider replacing the microswitches as they will be VASTLY easier to access with the top off. If not replaced, then by all means have them checked and treated to make sure they don't stick and are all calibrated properly. The touch points can get out of whack pretty easily. Ask me. how I know.
    blackbolt22 and Qavion like this.
