Convertible top weatherstrip | FerrariChat
Discussion in 'Mondial' started by russlv, Jun 3, 2013.
  1. russlv
    russlv Karting
    Feb 29, 2012
    63
    las vegas, nv,
    Russ Lorenzen
    I need to replace both sides of the weather strip that mates between the front windows and the side pillars of the top. Ferrari calls it a gasket, part # 6141130. Has anyone had luck with sourcing this anywhere else besides Ferrari at $80 each ?
    Thanks,
    RussLasVegas
  2. Statler
    Statler F1 World Champ
    Jun 7, 2011
    17,389
    wait... you can still get that window weatherstrip? I'll buy two at $80 per.
    Now if you can find the B-pillar itself....
  3. godabitibi
    godabitibi F1 Veteran
    Jan 11, 2012
    6,329
    Papineauville, Quebec
    Claude Laforest
    It's been talked a few times now. They are unavailaible and repros are too complicated and expensive to produce. The originals were near $600 each last time I checked. Good luck!
  4. russlv
    russlv Karting
    Feb 29, 2012
    63
    las vegas, nv,
    Russ Lorenzen
    Hi,
    I don't mean the b pillar rubber parts; I'm talking about just the weather strip between the front door glass and top. I went to check auto and found the exact same size product but with a closed circle contact area as opposed to the open area required. The whole box was 10' for $30. I just wanted to see if there were any repro parts that would have a more finished look than what my shaky hands could produce if I had to cut the circle part open :)
  5. godabitibi
    Jan 11, 2012
    6,329
    Claude Laforest
    If you can get a specialized wheatherstrip catalog there is a lot of different shape you may find what would fit your need.
  6. porphy
    porphy Formula 3
    1,209
    LouisvilleKY/Switzld
    Randall Gatz
    What is check auto? I googled it to no avail.
  7. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,816
    Old Dominion
    #7 soucorp, Jun 5, 2013
