Buy
Converting Newton Meters to Ft. lbs?
Discussion in 'Technical Q&A' started by 308GTS, May 19, 2004.
  1. 308GTS
    308GTS Formula 3
    Dec 27, 2001
    2,221
    TN
    I am in the process of a clutch change on my 85' 308QV and on one of the procedures I have it says 180 Newton Meters. What is the conversion to ft/lbs? How do you convert it? Thanks. I have other #'s that I want to convert too.
  3. GrigioGuy
    GrigioGuy Splenda Daddy
    Global Moderator Owner
    Nov 26, 2001
    26,546
    E ' ' '/ F
    Helen Bach
  4. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,687
    North shore, MA
    THE Birdman
    Lets see, my college physics book lists the conversion as 1 N = .225 lb and 1 m = 3.28 ft so,
    1 N-m = (.225 lb)*(3.28 ft) = .738 ft-lbs
    Please note that the unit is ft-lbs (i.e. feet times pounds) not ft/lbs.
    Birdman
  5. Frank R. Masiarz
    Nov 10, 2003
    126
    Frank R. Masiarz
    Hi............
    Haven't performed the unit conversions myself, but you can use the Google calculator function. Enter "180 newton-meters in pound-feet" into the Google search engine and you will get an answer of 132 pound-feet.
    Use of the Birdman's conversion factor or the Tillman's equation will give you the same result. Seems like a lot of torque, unless you are bolting down cylinder heads on a Chrysler Hemi ??!!?
    By the way, the units of torque are pound-feet, not foot-pounds, a mistake I have made for many years. Apparently, the units of foot-pounds apply to another physical parameter, but I can't remember which one right now.
    Double-check your numbers with the torque tables which relate the size of the bolt, number of threads per inch [centimeter] and the material into which you are torquing the bolt for "ballpark" torque figures.
    Good luck !!
    Frank...........23005
    www.masiarz.net/bb_resource
  6. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    5,989
    Toronto / SoCal
    Rob C.
