Cool 4Rari System | FerrariChat
Cool 4Rari System
Discussion in 'Ad Archives' started by ZIP22, May 15, 2014.
  1. ZIP22
    ZIP22 Karting
    Jun 7, 2009
    157
    For sale is an extra set of the "Cool 4RaRi" system I developed to keep my F430 running cool by extracting excessive engine bay heat at all times. Since I'm always concerned with heat build-up, I'm sure some of you share the same sentiment.
    The easy to install and autonomous Cool 4RaRi system, benefits are:
    - the OEM transmission crush box is removed in place of a high volumetric efficiency fan with similar weight (aka NO weight penalty)
    - one wire installation from the cabin to the engine bay
    - keeps the engine bay cooler as much as 100-150+ deg Fahrenheit
    - system automatically stays on for up to 15 minutes after engine shutdown
    - heat is extracted up to 600 cubic feet per minute!
    - the extracted heat helps increase the low pressure area at the diffuser (a quasi F1-type blown diffuser) which keeps the car more planted
    - no longer have to worry about keeping the bonnet up after parking in public places :)
    Best of all, only 1 wire is routed from the engine compartment back to the cabin. Only requires a total of 4 wires to easily hook-up and get it running! A Ferrari tech, or DIY person familiar with their Ferrari, can have this system installed and running in about an hour!
    More info here:
    https://www.ferrarichat.com/forum/360-430/447521-beat-heat.html
    $299 with shipping anywhere in the USA!
  2. George Vosburgh
    George Vosburgh F1 Rookie Silver Subscribed
    May 26, 2011
    4,380
    Pittsburgh, PA / Chautauqua, NY
    This is the same unit that is standard on the 458 special.
  3. ZIP22
    ZIP22 Karting
    Jun 7, 2009
    157
    I've received a lot of PMs on what the system looks like. Below is the picture of the kit. It's relatively intuitive and easy enough to install for a seasoned DIYer. It's includes full colored instructions and hardware to get your Ferrari running cooler! ;)
  4. Dave360inAZ
    Dave360inAZ Rookie
    May 3, 2014
    21
    Peoria, AZ
    Dave Farney
    Do you still have the system? I have also been looking at Dynamic Technology Group's Ferrari transmission cooler for the 360 (which I own). Have you seen this or have any thoughts on the concept?
  5. tradewinds808
    tradewinds808 Karting
    May 6, 2014
    70
    Illinois
    Brandon
    Pretty cool (no pun intended) I'm guessing by the single relay it is on all the time? I have a similar set up in my track car. I'm using two relays though. And they are linked to a STACK Pro water temp gauge that you can program to turn on at a certain temp and it will turn off when the temp goes down. Also will stay on when you turn the car off to blow more heat out while parked. Pretty nice feature in those little gauges.
  6. F430addict
    F430addict F1 Rookie
    Sep 17, 2010
    4,460
    Very cool concept.
  7. whatheheck
    whatheheck F1 Rookie Owner
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Awesome!
  8. -CD-
    -CD- F1 Rookie Silver Subscribed
    Jun 7, 2005
    3,839
    near the Nürburgring
    Christian
    Do you ship international?
    I would like to buy a set! :)
    Greetings Christian
  9. ZIP22
    ZIP22 Karting
    Jun 7, 2009
    157
    Hi Christian, we sure can! We accept PayPal. :)
    The one other bonuses we've noticed in hot weather testing for the past few months is that not only does the system keeps the engine bay significantly cooler and help ground effects at speed but, due to the strong cfm fan we use, it also keeps dust buildup to a minimum around the rear area of the car in general. We've also noticed that it also minimizes cold start emission smells an added bonus especially if you have a spider.
  10. alvchua
    alvchua Karting
    Feb 16, 2011
    57
    Adelaide, South Aust
    Hi - interested too if you can ship internationally. How do I proceed from here to purchase this?
  11. -CD-
    Jun 7, 2005
    3,839
    Christian
    deal! :)
  12. F430addict
    Sep 17, 2010
    4,460
    Would love to get a set but need to figure out how I'm going to get around fitting it over the cosmetic challenge tow hook.
    Sent from my SM-N9005 using Tapatalk
  13. open roads
    open roads F1 Rookie
    Jan 28, 2007
    3,799
    Sarasota, Fl.
    Stan
  14. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    As I posted on you other thread I am very interested.
    Just waiting on some photos and detailed installation on a 360 Spider.
    Thanks!
    Dan
  15. ZIP22
    ZIP22 Karting
    Jun 7, 2009
    157
    Hi Dan, we'll definitely get some photos and installation instructions to you once we have our other 360 client install his system. :)
  16. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Sounds good. Looking forward. Thanks.
    Dan
  17. cars_drive_me
    cars_drive_me Rookie
    Mar 10, 2015
    9
    Seattle area
    Greg
    Hi this sounds great, as my engine bay is hotter then ever since installing some headers. Do you still have these available? If so I'll buy a set from you.
    Sorry that I can't send a PM, as I just signed up recently on fchat, and I'm stuck on probationary mode.
