Coolant and oil for 355 | FerrariChat
Discussion in 'Technical Q&A' started by BigSky355, Mar 28, 2005.
  1. BigSky355
    BigSky355 Karting
    Nov 8, 2004
    196
    Montana
    Chris
    Questions for a 355,
    Does the brand of oil matter as long as it is a synthetic (I will have trouble finding more exotic brands out here so hopefully Castrol or Mobil 1 will suffice. 10/40 wt correct? Also, will any brand of coolant work as long as it is OK for aluminum engines (and I am assuming I simply dilute it according to temperature conditions)?
    Thanks,
    Chris
  2. f355spider
    f355spider F1 World Champ
    17,940
    Factory spec for the oil is a 5w-40 synthetic...a 0w-40 would be an acceptable substitute, but not a 10w-40. Several of us are using the Mobil 1 0w-40. Not sure on the coolant; if you are not going to use the Shell stuff, I would recommend using the BMW brand which is highly thought of, and reasonably priced.
  3. BigSky355
    BigSky355 Karting
    Nov 8, 2004
    196
    Montana
    Chris
    Dealership and the manual recommend AGIP (sp?) synth 10-40 wt. Is there a mail in source that could ship to me or should I just go through the dealership?
    Chris
  4. vincent355
    vincent355 F1 Veteran
    6,329
    Wine Country
    Vincent
    They recommend in the manual but the dealership last did my oil change with Shell. you can order oil through the dealership.
    A lot of people seem to use mobil 1 as it's available at most autoparts store.
    There is a great thread on oils if you search. Basically someone took the time to compile a lot of good data on different brands.
  5. vincent355
    6,329
    Wine Country
    Vincent
    Big Sky, are you in montana?
  6. AEHaas
    AEHaas Formula 3
    May 9, 2003
    1,461
    Osprey, Florida
    Ali E. Haas
    In the 1940's just plain mineral oil was sometimes used. For my '65 T-Bird they wanted an SA rated oil. That does not mean you have to use oils from back then. Use the most current, highest rated oils, they are way way way better in every respect.
    The oil for your 355 in my opinion is a 0W-30 or 0W-40 for hotter running. Mobil 1 is a good choice.
    aehaas
  7. BigSky355
    BigSky355 Karting
    Nov 8, 2004
    196
    Montana
    Chris
    aehaas,
    Been reading some of the recent detailed posts on oil. Appreciate the info, I went to the local auto store last pm and picked up some Mobil 1 0w-40. I think this will work well for me. Used Mobil 1 in the past for my 993 with good results.
    Vincent,
    Hi yes I am in Montana.
    Chris
  8. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    I use Mobile1 5w50 in my BB512i and BMW coolant.
  9. delaney
    delaney Formula Junior
    Nov 8, 2003
    704
    St Petersburg, FL
    PETER DELANEY
    I went to pick up some Mobil 1 but could only find 5 - 40 labelled for diesel engines/trucks and SUV's...."ideal for engines that are pushed hard...."
    Is there any formulation difference between this and the 5 - 40 recommended for the 355's?
    Regards,
    Pete
  10. fasthound
    fasthound Formula Junior
    614
    Maryland
    Kevin
    I'm using Mobil 1 0W-30 in my '96 355B and it runs great. Oil pressure is fine. I change it after track weekends.
  11. LeoExotic
    LeoExotic Karting
    Nov 29, 2003
    153
    Manalapan, NJ
    Leonardo
    I'm using Castrol 10 W60 for My M3....$10 a quart Dealership ONLY! what a rip off...I'm sure your oil for Ferrari's are cheaper.
  12. Rifledriver
    34,091
    Austin TX
    Not if you use the magic, only approved product on planet earth. The cost to the dealers from Ferrari (only source in NA) is about what you are paying retail.
  13. rjnavion
    rjnavion Karting
    Nov 1, 2003
    128
    Gate, OK (western O
    Ron Judy
    Chris in Montana,
    You may order AGIP oil at www.performatek.com. Price sounds okay and they have a set shipping charge determined by the cost of your order and it is very reasonable.
    Ron
  14. f355spider
    17,940
    Nope, I have seen Shell Helix (synthetic 5w-40) quoted as high as $20 per quart at FNA dealers.
  15. ncipps
    ncipps Karting
    Jan 24, 2005
    97
    I service italian cars and for all italian cars they suggest agip. Now agip is available through your dealer or you can agip and find a rep in your area. I use agip as my regular oil and it works great. www.americanagip.com is the website i think.
    Ciao for now
    Nick
  16. Rifledriver
    34,091
    Austin TX
    Nope
  17. TTG
    TTG Formula 3
    Jun 11, 2002
    1,555
    East Hanover, NJ
    Todd Gieger
    I have a 99 Serie Fiorano Spider and the manual says to use Shell Helix Ultra SAE 5W-40
