Coolant at 210 when idle in traffic | FerrariChat
Discussion in '360/430' started by Normal Guy Supercar, Jul 29, 2017.
  1. Normal Guy Supercar
    244
    Austin, Texas
    Daniel Hurlbert
    Hello again fellow Ferrari owners.
    I searched on this but didn't find exactly what I wanted to know so here we go...
    Yesterday it was 104F here in Austin, and I was driving home from lunch in the 430 in somewhat heavy traffic, and while idle the car got up to almost 210F coolant temp. Once moving again, it came back down to 200-205 pretty fast. Although not a big deal, it was a little concerning that it's not able to hit equilibrium at idle and the temp went up. My concern is whether or not this is being caused by my aftermarket exhaust or if it's just normal. If it's the exhaust I want to look into designing a heat shield or some other way to keep the engine bay temps down a little more.
    My questions are:
    1. Have you driven your 430 in traffic at 100F+?
    2. If so, what temp did it get up to?
    3. Do you have the factory exhaust?
    Thanks!
  2. mark.ruffley
    mark.ruffley Rookie
    Mar 13, 2017
    32
    Hi there. Greetings from Dubai. It was 110deg today... My F430 spider did not go over 170 in normal driving. At traffic lights it moved up to 180 or so...factory pipes but with middle east heat pack. Was in the heat for about 45mins. Hope that helps. Mark
    Sent from my SM-G930F using Tapatalk
  3. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Check your cooling system. Radiators (are they covered with debris?), fans (are they both running?), coolant (is it full?), thermostat (when does it open?). Are there any trouble codes?
  4. Sled Driver
    Sled Driver Formula Junior
    May 13, 2010
    494
    Stokesdale, NC
    Emery
    #4 Sled Driver, Jul 29, 2017
    210 is normal in stop & go traffic. That's what the fans are regulated to maintain.
    Dubai's info is wrong.
    Even in 75-80 outside temps my car always show 210 when it's been stationary for awhile in traffic.
    Radiant heat from your exhaust won't effect your coolant temps
    You can verify this with your local dealer
  5. Sled Driver
    May 13, 2010
    494
    Stokesdale, NC
    Emery
    The fans operate staggered. Both don't come on together.
  6. PFSEX
    PFSEX Formula Junior
    Jun 30, 2006
    843
    Las Vegas
    John Ratto
    These new cars are designed to run hot because it is good for lowering emissions.
    My 2003 Corvette used to regularly get to 240 - dealer said it was normal.
    That said - 360s run cool. I get to 210 idling on hot days (Las Vegas - pretty warm).But driving on the road at 100 ambient I tend to run around 170.
    You sound normal to me.
  7. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    I was recommending to check if they both are functional.
  8. Normal Guy Supercar
    244
    Austin, Texas
    Daniel Hurlbert
    Verified the fans are working properly. It sounds like it's normal. I didn't have the car last summer so I didn't get to learn it's behavior in very hot ambient temperatures. I just wanted to verify so thank all of you very much for chiming in! I appreciate the peace of mind.
    One less thing to worry about. [emoji3][emoji106]
  9. John_K_348
    John_K_348 F1 Rookie
    Sep 20, 2013
    2,753
    Boston, MA
    John E. Kenney
    I turn on the heat with the top down if it get's worrisome. But this only works if the alternator doesn't fail ;)
  10. Sled Driver
    May 13, 2010
    494
    Stokesdale, NC
    Emery
    The problem with generic answers is............
    "coolant full" without describing what that means.
    With the Coolant cold, open expansion tank & verify it's not dry & has approximately 1-2 inches of coolant in the tank.
    How do you get BOTH fans to run without a SD2/3?
    Push the STOP or OFF button on the A/C pnl. Start the car & let idle for 10-15 minutes till one of the fans comes on as the temps rise above 200 or so. Turn on the A/C by pushing the Stop/Off button & the other fan should turn on. As the temps drop one fan will cycle on & off
    Trouble codes? I think he would have mentioned a check eng light, but you never know.
    When should the thermostat open? Give him a temp range & what temp it shows during steady state freeway driving. Over time (1/2hr or so) the oil temp will match the water temp.
    I'm not picking on you in particular, I get frustrated with generic replies to questions
  11. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    I carefully listed a few things to check that could influence indicated temperature. It's not my goal to provide a specific solution. Typically that isn't possible from a written description. As far as coolant level goes. I can't tell you the number of car owners that have never looked. Are the fans running? A fair question. You described the method that didn't require a scantool. Thermostat opening temp? Not really likely to be a problem in this case. One simple way is to observe when the coolant reservoir starts to get warm? Check engine light? Just because it wasn't mentioned doesn't mean there wasn't one. Some codes don't trigger the light.
    In this case there was likely no real problem.
  12. drcripp
    drcripp Karting
    Nov 1, 2016
    123
    Pittsburgh
    David Crippen
    I got caught in my 360 in an unexpected traffic jam the other day at about 88 degrees in Pittsburgh. Happened to pull up behind a black 360 and this guy was really worried. He couldn't take his eyes off the dashboard (temp gauge) and started getting pretty animated. He'd probably been sitting there longer than me. This lasted about 15 minutes sitting idling but no place to pull off due to tight road. My temp hit 210 and stayed there. Didn't budge. All I did was turn the A/C off and open the windows. Finally we crept to a feeder road, he rapidly pulled off, jumped out and opened his rear bonnet.
    So I neurotically worry about heat but I've never really had a problem. I've also been told that 210 is "normal" in such situations. I'll start sweating (literally) if it hits 220?
  13. chdavis
    chdavis Karting
    Sep 19, 2015
    66
    Philadelphia, PA
    Christopher
    It's funny - these cars always "feel" like they're running hot, but they're really not. They just have accurate gauges.
    My Range Rover Supercharged runs hotter than my 430, but it has a tableau gauge typical of most production cars, which buffers the temperature reading within a given acceptable range so it always sits perfectly in the middle.
  14. ShadowF430
    ShadowF430 Formula Junior
    Mar 29, 2017
    270
    Portland
    Jason
    I think everyone has already said it but sitting at idle is normal. The day I got mine it almost went to the next notch for a few seconds (about 225 I'd guess but still a whole botch below danger zone thankfully) and I realized this shouldnt happen. It was 105, I was going up hill 10 mph out but thought it still shouldn't do that. Soon as I started driving faster and it went back below middle. Drive at night not an issue but I didn't like the idea so did some research. Test your fans. Turn on the a/c both should kick on eventually. When it hits 210 they go INtermittenly. I had a bad relay. Ferrari newport replaced the relay and something else related to the system, I can't think of the name. Since that, it only gets to 205 or so when it's 95 plus out stop and go. Check to make sure both fans are kicking on. If your not going above 210, I'm sure you are fine buddy.
