Coolant change question (Testarossa). | FerrariChat
Discussion in 'Technical Q&A' started by Threeofnine, Sep 13, 2024.
  1. Threeofnine
    Threeofnine Formula Junior
    Dec 11, 2020
    431
    Birmingham, AL USA
    Jarrod Heath
    I’m about to change out the coolant in my Testarossa, 88.5 US spec. I know both radiators have drain plugs, but there are also drain plugs on each head. Is it absolutely necessary to remove the drain plugs in the heads? I’ve seen some threads claim that just draining the radiators is largely sufficient as long as you do frequent coolant changes.
  2. raemin
    raemin Formula 3
    Jan 16, 2007
    2,365
    Lyon (FR)
    R. Emin
    Not a Testarossa, but before summer I just remove 5l of coolant and replace with distilled water + water wetter. I just do the opposite for winter (add 5l of fresh -37°C coolant) for winter storage. So I basically replace a third of my coolant additives every 6 months.
    For drainage, I only use the radiator petcock not the plug on the block. When I need to thoroughly clean the system I remove the temperature fan switch and flush 5 times with 5l of distilled water.
    As for coolant I prefer to use coolant with silicate: although it is less efficient it does protect aluminium better. This being said the best coolant additives are dependant on the type of water used (US, asia and Europe are different), so your supplier may provide you with other types of coolant, but the issue is to favour a coolant designed for aluminium that reduces cavitation.
    Threeofnine likes this.
  3. ago car nut
    ago car nut F1 Veteran
    5,516
    Madison Ohio
    David A.
    Remove the plugs on the engine, it is not hard.
  4. BAK5150
    BAK5150 Rookie
    Aug 24, 2024
    24
    London
    Burhan
    Just draining from the radiators will be sufficient. Draining the block is not that big of a deal if you don't do it. I would only drain the block as well if it's coolant that is contaminated or faulty.
  5. Rifledriver
    37,224
    Coolant additive packages wear out. Draining radiators and not the block is a waste of time. Its like brushing your upper teeth because the lowers do not matter.
    ago car nut likes this.
  6. Motob
    Motob Formula 3
    Nov 11, 2003
    2,384
    Frederick, Maryland
    Brian Brown
    When you drain the engine from the plugs on the backs of the heads, the coolant will flow down into the precats under the heads and soak the insulation in the precats. It make a toxic stinky coolant steam when you fire the car back up for the first time for some moments. I use flexible funnels under the drains in the heads to keep the coolant out of the precats when draining out the coolant.
