Coolant drain technics ? | FerrariChat
Discussion in '360/430' started by Skippr1999, Oct 23, 2014.
  1. Skippr1999
    Skippr1999 F1 Rookie Silver Subscribed
    Dec 22, 2009
    4,513
    I'm wondering if anyone has any ways of getting maximum drainage. Pulling the radiator plugs in the front only drains about one gallon.
    Thanks,
  2. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,115
    Calif
    Brett
    Search a few posts here...Rifledriver posted a series of procedures to do it corrctly somewhere here...
  3. Skippr1999
    Dec 22, 2009
    4,513
    I've read all I can find. All I've seen is to blow compressed air into the expansion tank which I've been told could blow a head gasket.
    Any link to Rifledrivers post would be appreciated.
  4. English Rebel
    English Rebel Formula 3
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    IIRC when I watched my indie mechanic do mine there are two drain valves (or plugs) on the block -- one on either side. You have to pull the under tray to get to them. I believe it's item #10
    Alan
  5. Black360
    Black360 Formula Junior
    Oct 11, 2010
    436
    East of Eden
    Steve
  6. THINKFAST
    THINKFAST Karting
    Jan 13, 2011
    195
    Earth, mostly ...
    Awsome write up Steve...Thanks for posting it again. Mods, This should be in the DIY /technical section sticky.
    Well done again.
  7. Skippr1999
    Dec 22, 2009
    4,513
    Thanks for the responses. So, are you guys pulling the plug on the block ?
    Or, some other technique to get the coolant out ?
