Coolant hose dia under plenum (308) | FerrariChat
Discussion in 'Technical Q&A' started by Meister, Apr 27, 2006.
  1. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    Anybody know off the top of their head the diameter of the short coolant hose under the plenum on a 308? Looks to be in the 1 3/4" to 2" range...
    Also, while I'm in there any need to upgrade to a high temp material or just go with over the counter stuff?
    Thanks.
  2. Doc
    Doc Formula Junior
    Sep 13, 2001
    886
    Latham, New York
    Bill Van Dyne
    I used 1 5/8" hose for my '85 308. Napa Gold Stripe is the brand I used. It was very thick-walled, high quality stuff. Some guys allege using 1 1/2" hose, but I couldn't get that size to fit on my car. The 1 5/8" was easy to install for that location and worked out fine. I used double clamps all the way around to insure a leak-free seal.
  3. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    Thank you!
  4. cavallo_nero
    cavallo_nero Formula 3
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    I am replacing the coolant hose coupling that comes up from underneath the car right before the front bank on the 308 - the coupling is right behind the oil separator for the crankcase breather system. I can get to it by removing the driverside rear wheel. Is this hose 1 5/8 inner diameter also???
    thanks
  5. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    #5 Pizzaman Chris, Jun 5, 2007
  6. cavallo_nero
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    I replaced the bad coolant coupling hose, those hoses are 1.5 inch ID, it is a tight fit, but works well. the 1 5/8 ID hose looked a bit sloppy with to much clearance. i used NAPA straight hose....
  7. jwise
    jwise Formula Junior
    Apr 2, 2003
    781
    Portland Maine
    I use the same thing. 1-1/2" goes on fine with a little coolant for lubrication.
    There is radiator hose grease designed for this, or even a little lithium grease will be o.k.
  8. Steve Magnusson
    26,930
    (If I may be allowed a small joke) The Designer didn't specify 1 1/2" or 1 5/8" hose -- it's metric! ;)
    Seriously, I believe the stock size is 38mm (1 1/2"), and it is a b*tch to get on in some places. 41mm (1 5/8") works OKish (and is a heck of a lot easier to get on), but you're relying more on compressive forces from the clamp for a good seal compared to the 38 mm (but it's not a huge point).
  9. BigTex
    79,398
    Houston, Texas
    Bubba
    Just check out the metric hoses for Euro cars....at the NAPA or the closet VW dealer of your choice!
    Very good point 91tr.......
  10. RVIDRCI
    RVIDRCI Formula 3
    Dec 1, 2005
    1,576
    Long Beach / Phoenix
    Luigi
    41 mm (1 5/8") Gates green stripe. Quality, thick wall, flexible, Bulletproof, easy install, use premium quality stainless steel wide band clamps.
    my .02
  11. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,394
    Dumpster Fire #31
    SMG
    meteric is a PITA find however if you're into silcone :D then Pegasus has your number. they stock the metric hose, I bought 3ft and sent the left over 1.5 ft to another F-chatter.
    the real PITA is the fuel filler hose on the Mondial and 3x8's. don't even get me started on that one.
