Coolant Hose Part Number | FerrariChat
Discussion in '360/430' started by espen.handeland, Feb 20, 2023.
  1. espen.handeland
    Aug 7, 2022
    8
    Espen Handeland
  2. 360Grigio
    360Grigio Karting
    Nov 1, 2010
    150
    Steve
    My guess
    On "table 23 - Nourice" on Ricambi's website, it looks like part #17616, rubber hose from engine to nourice.
    espen.handeland likes this.
  3. Fcar tech
    Fcar tech Karting
    Oct 22, 2021
    108
    Always nearby
    XXXX
    The correct part # 65831500
    I've changed enough of them to know the #
    espen.handeland and 360Grigio like this.
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,536
    San Carlos, CA
    Mitchell Le
    That looks like a 16mm heater hose. Do you even need a custom hose or just a good length of 5/8 inch hose?
  5. 360Grigio
    360Grigio Karting
    Nov 1, 2010
    150
    Steve
    I was looking at the photos of when my car had its belts changed and comparing the hose location in the photos to the diagrams. Thus the incorrect guess. Thank you for the correction.
    Fcar tech and espen.handeland like this.
  6. espen.handeland
    Aug 7, 2022
    8
    Espen Handeland
  7. espen.handeland
    Aug 7, 2022
    8
    Espen Handeland
    Thank you!
  8. espen.handeland
    Aug 7, 2022
    8
    Espen Handeland
  9. Fcar tech
    Fcar tech Karting
    Oct 22, 2021
    108
    Always nearby
    XXXX
    That clamp you circled should be fine. It is attached with #182301 clamp which it too should be ok.. The bracket that it attaches to is the common item to break.. That's what is broken. If you remove the clamps it might make more sense. Once fixed.. it will break again in time..
    The bracket can be repaired. Check your clamps again.. you will see what I mean.
  10. espen.handeland
    Aug 7, 2022
    8
    Espen Handeland
    Thank you for sharing your knowledge.
    The Clamp and Bracket is completely missing on my car, the picture is from another car.
    I have found #182301 in the Spare Parts Catalogue.
    What would be the Part Number for the Clamp and Bracket for Coolant Hose 65831500?
  11. Fcar tech
    Fcar tech Karting
    Oct 22, 2021
    108
    Always nearby
    XXXX
    That's something I can't help you with..
    Perhaps a Ferrari parts retailer can help you.
    I'm glad that was just a picture of a random 360.. because if that was yours, you have more serious problems to deal with than just some clamps.
    Good luck finding your parts.
  12. ItalGerBrit
    ItalGerBrit Formula Junior
    Mar 15, 2016
    906
    S La
    FCar Tech.
    Could you tell us what potential problems that you see in the picture? Car has not been driven much because the pulleys are rusted/ Maybe potential seizing? Car near ocean, salt?
  13. espen.handeland
    Aug 7, 2022
    8
    Espen Handeland
  14. Fcar tech
    Fcar tech Karting
    Oct 22, 2021
    108
    Always nearby
    XXXX
    2 different size clamps. They are not the same.Your missing clamp part number is just a simple 1" rubber lined hose clamp with the the hole in it to enable one the ability to bolt it securely. Commonly found in a hardware store. It's not rocket science.
    ItalGerBrit and espen.handeland like this.
