430 - Coolant Hoses | FerrariChat
430 Coolant Hoses
Discussion in '360/430' started by AandSC, Apr 21, 2025.
  1. AandSC
    AandSC Formula Junior
    921
    Jax, FL
    Allen
    2008 F430, 26,4XX miles. Did about 50 miles this past Saturday and commenced my annual service. When I removed the engine undertray I noticed what appeared to be a clear liquid on the large bottom coolant hose and at the base of the oil/water pump. The liquid was slippery, so doesn’t appear to be condensation. There are no apparent leaks from the water/oil pump, and there are no deformations or apparent leaks from the coolant hose that had several droplets and a sheen from what appears to be coolant. The coolant level in the reservoir is very slightly low. After changing oil I warmed the engine up to normal operating temp and no sign of any leaks or “sweating”.
    I’m ordering all the hoses (17 year old hoses due for replacement) and I’ll do a vacuum and pressure test to see what they show but has anyone seen a similar “sweating” from the coolant hoses that might indicate they are failing?
    Pics to show where the liquid was.
  2. GogglesPisano
    GogglesPisano F1 Rookie
    2,985
    East Bay, California
    Joe
    The problem is that your engine bay is too clean. No protective dirt layer :D
    On a serious note, 2008 should have had silicone hoses. Don't those have a much longer lifespan?
    AandSC likes this.
  3. AandSC
    921
    Jax, FL
    Allen
    Joe,
    I threw some rust, dirt and old oil on the engine and surrounding area to see if that helps. :D
    My understanding was the silicone hoses are supposed to last longer, but how long is the normal lifespan of coolant hoses subjected to the 430’s engine bay heat?? It’s also odd that the sweating didn’t happen when doing the post-oil change engine run.
    GogglesPisano likes this.
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,918
    Isle of man- uk
    You will have fun doing the radiator hoses, have to open the front part to get to them
  5. GogglesPisano
    2,985
    Joe
    Did you end up doing the vacuum test? Really curious if your silicone hoses failed.
  6. AandSC
    921
    Jax, FL
    Allen
    Joe,
    Not yet. Was out of town last weekend and really busy work week. Planning to tackle this weekend.
    I have been accumulating all of the coolant hoses in anticipation of changing them out. I don’t want to have a hose failure at an inopportune time. Will give me peace of mind for another 17 years.
    Haven’t seen any real consensus on how long these hoses should last, otherwise I would just change out the one that’s weeping.
  7. GogglesPisano
    2,985
    Joe
    Thanks. I'm interested because it would be good to spot early trends as the cars age. Doing a bit of research on silicone hoses, it seems that it is not uncommon for them to "sweat" more than rubber because they are more permeable. So, the symptoms you are seeing might be normal operation. Maybe someone more experienced can comment on that. Obviously, nothing wrong with putting on new parts but it would be good to understand for others that might find themselves in the same situation.
    AandSC likes this.
  8. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,381
    Santa Clarita, CA
    I’ve never seen or heard of a radiator hose sweating, on any car. Could it have been condensation from running the air conditioner? Just a guess.
  9. AandSC
    921
    Jax, FL
    Allen
    Definitely not condensation given location, oily feel, blue residue on undertray, and evidence on the hose.
    Did quite a bit of reading and there are instances where this has been observed, related to failing hoses.
    Here’s one link that I found interesting. https://motoiq.com/silicone-radiator-hoses-not-for-the-street/
  10. GogglesPisano
    2,985
    Joe
    I read that as well. I was hard pressed to find more than a few articles that aligned. Some sources say they last 5-10 years (which is rediculous considering that's what rubber easily lasts to) and other saying they will outlast the car, which is equally confusing. Plenty saying you will lose coolant gradually because they're porous if you search exactly for that, but I have never experienced that myself or never heard of it happening before. Who knows though, maybe there are various grades or constructions that exhibit each of those characteristics.
  11. AandSC
    921
    Jax, FL
    Allen
    Joe’s post caused me to relook at this effort. The replacement hoses I’ve gathered up so far all say EPDM, so they aren’t silicone. And these are the latest versions of the coolant hoses. So I went out and looked at what was on the car and they are also marked EPDM. Not silicone.
    Supposedly EPDM is used as they are less costly, but over $2,000 for all of the hoses doesn’t support this as a factor.
    Maybe I should reverse engineer all of these hoses and start a new business….
  12. GogglesPisano
    2,985
    Joe
    Interesting. So rubber basically. I wonder why we were all under the assumption they changed to silicone then?
  13. boostedt0y
    boostedt0y Formula Junior
    Dec 25, 2014
    773
    Bay Area, CA
    I changed out all the coolant hoses on my scud at 11k miles. Some of them were already showing signs of ballooning.
    AandSC and GogglesPisano like this.
