coolant issue--need help | FerrariChat
Discussion in '308/328' started by gtbman, Apr 17, 2011.
  1. gtbman
    gtbman Karting
    Sep 28, 2009
    69
    just took the 328 out for about 20 miles, stopped at a gas station and coolant was coming out behind the left rear tire. Got the car home, waited 10 minutes, started to unscrew the coolant cap and it came bubbling out---what is this ?
  2. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,872
    Mike 996
    A new cap may be in order. Old ones get weak and tend to blow off before they should. My 328 did that occasionally but a new radiator cap - a standard 15 PSI Stant, available at any auto parts store - eliminated it. If it continues with a new cap, there could be issues involved that we don't need to talk about now. Try a new cap and see if that solves the problem.
    It is normal for coolant to come "bubbling out" if you remove a cap on a hot engine.
  3. gtbman
    gtbman Karting
    Sep 28, 2009
    69
    Visually the cap looks fine, but I guess that's not really definitive, is it . There did not appear to be any leaks from below.
  4. PV Dirk
    PV Dirk F1 Veteran
    Jul 26, 2009
    5,401
    Ahwatukee, AZ
    I had the same issue, at one point my car started purging a bit of coolant every time I drove it. It went on for a couple months before I put a new cap on it. Problem gone. My old cap just lost the proper spring tension. Try that first.
  5. BigTex
    79,380
    Houston, Texas
    Bubba
    Definately get a new cap but as noted 10 minutes is not enough time IMO to safely remove the expansion tank cap...the engine/coolant is still hot.
  6. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,321
    +3
    Get a new cap, I am on my 3rd in 11 years & make sure its a 1.1 bar cap at that.
    I carry a spare in the toolkit because once it starts tossing out coolant its a short walk to overheated heads etc.
  7. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    +4 on the new cap. They are not expensive, so just do it. But if, in your exuberance to get the car ready for the spring, you "topped up" the coolant and didn't leave enough room in the expansion tank, the system could just be spitting out some of the excess. I used to have that problem with old Jaguars. You change the fluid and then drive the car for a while, stop and watch the puddle of coolant grow under the car. After two or three rides, the system found its level and that was that, no more spitting. I seem to remember the 308 doing that also after I did the engine-out service and refilled the system with fresh fluid.
  8. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,872
    Mike 996
    Thats a good point - the "full" level in the exp tank (when engine is cold) is a bit low in comparison to what you might expect. I don't recall the specified level but it's not unusual for them to spit a bit after draining/refilling the coolant because it's easy to add a bit too much coolant.
    FWIW, I think everybody pretty much uses a standard 15PSI rad cap but the specs on the 328 actually call for 12.8 PSI if I remember right. Seems to me if you really used a 13psi cap (is there such a thing?) it would tend to spit quite regularly. Fortunately, the radiator seams have proven able to handle 15PSI! :)
  9. gtbman
    gtbman Karting
    Sep 28, 2009
    69
    I realize what might be my stupid mistake, I topped off the coolant for winter storage but did not remove it for spring time driving, perhaps this was the cause.
  10. gtbman
    gtbman Karting
    Sep 28, 2009
    69
    How far below the top of the filler spout should the coolant be when the car is cold ?
  11. PV Dirk
    PV Dirk F1 Veteran
    Jul 26, 2009
    5,401
    Ahwatukee, AZ
    There was a spec in the owners manual. I think on my car is was 10cm. 6 inches. I think when cold I'm 1/3 full in the expansion tank. The measurement is just what comes to mind, I could be completely off.
  12. gtbman
    gtbman Karting
    Sep 28, 2009
    69
    I'm confused are you aying 10cm OR 6 inches ?
  13. BigTex
    79,380
    Houston, Texas
    Bubba
    The expansion tank should be roughly half full with the rest air volume.
    You can overfill it without harm if you then air bleed the front radiator.
    328s have a Tstat bleeder as well.
    Once complete with system belled let it all cool donw and recheck it 'at rest', you need/want about 3" -4" of air, down from the neck of the cap.
    I'm calling all this from memory and a decade of ownership I'm sure The Books give an absolute dimension in Italian somewhere......
  14. BigTex
    79,380
    Houston, Texas
    Bubba
    PV Dirk has a Mondial with a different tank/volume........the point is the same, don't jam it full with coolant....
  15. BigTex
    79,380
    Houston, Texas
    Bubba
    What year do you have?
    Fill out your profile...
    Do you have "The Books"?
  16. doug328
    doug328 Formula 3
    Mar 11, 2004
    1,599
    The Space Coast, FL
    Doug B
    Thats the best "every day advice". I believe the owners manual specifies 6 cm from the top of the tank to level of coolant. I leave the tank a little more than half full. If the car has been sitting for some time, maybe some air as leaked into the system. Best to have the car at a slight incline with the front higher than the rear. While the engine is running, bleed the radiator first then can do the thermostat housing. when cool check/adjust the level of the tank. I change the coolant in my 328 every year and it takes about 3 times for me to get all the air out of the system. But when done and the proper level in the tank, I've had no problems with any coolant burping out of the system. I do have a new cap from a couple of years ago when I overhauled the coolant system. Good luck and keep driving.
  17. Ehamilton
    Ehamilton F1 Rookie
    2,642
    Durham, NC; USA
    Eric Hamilton
    Stick your index finger into the reservoir. Your fingertip should be in the coolant..
    This is, obviously, an engine-cold test.
  18. BigTex
    79,380
    Houston, Texas
    Bubba
    LOL! Yea.....6 cm sounds right for a 308/328 tank...when cold.
