Coolant leak 308 top of engine | FerrariChat
Discussion in 'Technical Q&A' started by RVIDRCI, Nov 8, 2006.
  1. RVIDRCI
    RVIDRCI Formula 3
    Dec 1, 2005
    1,576
    Long Beach / Phoenix
    Luigi
    I have noticed (about a week ago) that I have a very small coolant leak at the upper part of my 308 QV motor. So small in fact that the only way I noticed it is coolant accumulated in the valley below the intake manifold, and I saw it while I had the right inner well removed to do a water pump tensioner bearing replacment. I think on a hot motor it just evaporates as it leaks out! I checked and tightened all of the hose clamps etc. @ the water neck/pump/coolant pipes and assumed I had it fixed. Upon running hard at the track this last weekend, I had no heat issues, no coolant level problems etc. but after driving home and shutting down, overnight the valley area filled about a 1/8 inch deep with clean greenblue coolant. My motor is spotlessly clean, and upon inpection on a cleaned up warm running motor (using an inspection mirror, penlight, dry paper towel on longnose pliers etc.) I can find no evidence. But the coolant in the valley shows up again after sitting overnight after a hard run.
    Any ideas on how to find it, experience with 308 Qv chronic or usual culprits in this area ? Does not appear to be hose connections or coolant rails under intake.
    Thanks,
    Luigi
  2. Dr Tommy Cosgrove
    36,572
    Birmingham, AL
    Tommy
    There IS a hose under the intake manifold. It is a short one, though, and a ***** to replace because you have to pull the intake off to do it. I had to on mine about 7 years ago after it blew. I would not drive it until it is replaced because it will not wait to bust when you are pulling in your driveway. Mine didn't.
  3. fastaone
    fastaone Karting
    Jan 9, 2004
    192
    Long Island
    Peter F
    Ditto that... same happened to me, 2 days after I had the waterpump replaced... That's when I decited to replace ALL the rubber
  4. RVIDRCI
    RVIDRCI Formula 3
    Dec 1, 2005
    1,576
    Luigi
    Thanks for the input boys, but let me elaborate. I can see and have checked all hoses, gasketed flanges, pipes etc. under the intake as best I can with the intake and plenum intact ( I know whats under there ). I am looking for a way to pinpoint the teeny leak without just replacing everything on the top of the motor that might be leaking.
    -Luigi
  5. bwassam
    bwassam Formula Junior
    Jan 3, 2005
    635
    North Bend, Oregon
    Robert Wassam
    I replace my hose under the manifolds when I had an air leak in the induction system about a year ago. Just recently I blew a coolant hose that is on the left end of the engine. (Distributor end) That hose goes to the heater boxes located in the front of the car. It's tough to change that one because it goes through the center tunnel of the car. If you're going to remove the manifolds, I suggest that you change that hose as well as any other coolant hose that you can easily get to when you have all the room to work while the manifolds are off the car. Be sure to plug the intakes before you pull any hose in order to keep coolant fluid and other debris out of your engine.
    Actually, there are 4 (four) hoses that go to the front of the car. Two for the radiator, and two for the heater system. Since one hose has a hole in it, you can bet that the rest of the hoses are near the same state.
    By the way, I've been thinking about converting the screws that holds the fenderwell to zeus (sp) fittings. That way I can remove the fenderwell with a few half turns with a screwdriver. Any thoughts on this?
    I don't mean to steal your thread, but the question has been in my head for awhile. I know that it would decrease the value of the car slightly, but it would be a lot easier to get the fender well out of the way when I need to do that.
    Bob Wassam
  6. Dr Tommy Cosgrove
    36,572
    Birmingham, AL
    Tommy
    I won't hurt the value of the car at all. No one will know it was ever different. It MAY cost a point or two at a concours meet but I even doubt that the judges would even notice. Seriously.
  7. matteo
    matteo F1 World Champ
    Aug 1, 2002
    13,748
    On a plane somewhere
    Heir Butt
    Lou,
    it could be a simple loose hose that leaks under pressure. My old 78 had a similar leak and has a test, I double clamped the hoses and it went away. Once I replaced the hoses it stopped the leak with one clamp.
    There only two locations, except for a major engine issue, that coolant can come from. The hoses that cross over the valley on the way to the thermostat / water pump.
  8. RVIDRCI
    RVIDRCI Formula 3
    Dec 1, 2005
    1,576
    Luigi
    Matteo,
    Can you/I/anyone double clamp the short hose sections connecting the large coolant pipes under the plenum (I assume these are the ones you mean) with the plenum and manifolds intact ??? Its pretty tight in there, I have already snugged up the existing hose clamps, and that was no cake walk.
    Thanks for the input.
    -Lou
  9. matteo
    Aug 1, 2002
    13,748
    Heir Butt
    My old car was a carb so I just removed the airbox.
    I think with a long, thing screwdriver, small hand mirror, plenty of band aids it can be done.
    If you want, cruise on up to Valencia and we can give it a go.
  10. bwassam
    Jan 3, 2005
    635
    North Bend, Oregon
    Robert Wassam
    I serously doubt that I'll ever do a concours. I'll make the change over the winter. Thanks for the info.
    Bob Wassam
  11. POLO35
    POLO35 Formula Junior
    Feb 21, 2005
    792
    Treasure Coast Florida
    MATT
    Lou, I had the exact same mystery leak recently. It turned out to be the short hose...6"X22mm under the manifold. As previously posted, it is a pain to replace, but it can be done without removing the manifold. Remove airbox, use lots of u-joints and extensions to get at the hose clamps and slice/split old hose off with a sharp razor knife. Thats the easy part. Then go to local auto parts store and buy any 22mm radiator hose...mine was from a honda, and just cut off to match old hose length. To get the new one on, I used pulmber's grease...from Home Depot... on both hose and fittings and seduced/slipped the new one on. It's tough and tedious and you will have bloody knuckles.... But it can be done.
  12. PT 328
    PT 328 F1 Rookie
    4,015
    I replaced my coolant hose from the expansion tank to under the plenum in my 328. Now my car is in for service and having the water pump changed. I took the old hose to autozone and asked if they had anything similar. They were amazed at how thick the coolant line was. Needless to say I purchased a new hose from Ferrari of Silicon Valley for $45. As stated in previous posts it can be replaced with only the oil filter removed. Again, as stated before, with patience and bloody knuckles. Good Luck.
    Dan
  13. RVIDRCI
    RVIDRCI Formula 3
    Dec 1, 2005
    1,576
    Luigi
    Thanks for all of the input guys.
    Looks like its gonna be a trip to NAPA auto for some 22mm hose and to Rite Aid for a large box of those finger and knuckle bandaids. I think I will use silicone grease from my SCUBA save a dive kit to help coax it on. BTW that scuba pure silicone grease works great on the shift gate on f-cars (clear, non staining, improves shifting)
    -Lou
  14. f355spider
    f355spider F1 World Champ
    18,054
    Get a flexible, 1/4" extension socket...it will make removal and installation of the hose clamps much easier.
  15. Doc
    Doc Formula Junior
    Sep 13, 2001
    886
    Latham, New York
    Bill Van Dyne
    I was able to replace both hoses under the intake plenum on my '85 308 without removing the plenum itself. As stated, you'll need to remove the air box and a few other assorted things out of the way. If you can't find 22mm hose, I used NAPA Gold Stripe 1 5/8" hose with double clamps all around. It's a pita job, but not really difficult. I'm not a mechanic and was able to do w/o any problems. Also, do a search . Someone did a pictorial step-by-step a couple of years ago re: this job.
  16. RVIDRCI
    RVIDRCI Formula 3
    Dec 1, 2005
    1,576
    Luigi
    Done. Double clamped for now, until the "change all the hoses" project this winter.
    Not 22mm BTW, more like 42mm. The Gates green stripe is a nice product.
    -L
  17. POLO35
    Feb 21, 2005
    792
    MATT
    Sorry Lou, you're right...hose ID is actually 40mm....pn 102957 at Allferrariparts.com.
  18. RVIDRCI
    RVIDRCI Formula 3
    Dec 1, 2005
    1,576
    Luigi
    No worries. 40mm it is.
    -L
