Coolant leak 81 308 GTSi | FerrariChat
Discussion in '308/328' started by kemullins63, Apr 6, 2010.
  1. kemullins63
    kemullins63 Karting
    Feb 12, 2010
    78
    Kansas City Missouri
    Kirk
    Yes i know, another coolant leak thread... i've read others and not found what i have been experiencing exactly, so thought i'd give the experts another problem to chime in on. I have coolant leaking from under the water pump area but only after the car sits overnight and has cooled down. I have driven it, let it idle and come to temp and rev'd it, no leakage at all... it's only after it has sit and cooled down that i see a stream about an inch wide coming out from behind the car after about 12 hours of sitting. Any thoughts? I'd think under pressure it would leak more and i could locate it, but it doesn't.
  2. Steve Magnusson
    26,785
    When warm, the rubber components soften and seal better. Also, metals expand so cracks and gasketed joints can seal better when warm (even though the pressure is higher when warm). The tool you need to buy or borrow is a small hand pump made by Stant (Stant 12270) -- it mounts to the coolant filler neck, and allows you pressurize the system when cold:
    http://www.sjdiscounttools.com/sta12270.html
  3. kemullins63
    kemullins63 Karting
    Feb 12, 2010
    78
    Kirk
    Thanks Steve, I just ordered it... that will help a lot in chasing down my leak.
  4. F308fan
    F308fan Karting
    May 7, 2017
    162
    Peoria, AZ
    Tony Pacini
    #4 F308fan, Mar 6, 2022
    I just finished chasing down a similar leak; it was fine when hot and under pressure and didn’t leak until after being driven then parked for a few days. Most of it seemed to be coming the front (timing cover area) but I couldn’t see where it was coming from. Since it acted like a hose connection I checked the hose clamps that I could see and reach easily. Some had signs of leakage between the hose and pipe so I tightened the clamps, but none were in the area I was finding the majority of the drops (hanging from the bottom of the engine).
    I knew there were coolant tubes/hoses on top of the engine block and under the intake plenum. The only service invoice that came with the car showed “replaced hoses under manifold” with no part numbers, so I’d hoped they were good. I couldn’t be sure what was actually done.
    I bought a $30 wifi endoscope (brand = Nidage) in hopes of diagnosing the problem. I stuck it under the plenum and sure enough I could see leakage between one clamp and the hose and there was a small puddle underneath.
    I removed the intake plenum and continued to investigate with the endoscope. Believe it or not, removing the plenum didn’t allow me to see a whole lot more, but I was able to scope each end of each hose and isolate the leaks. The bottom-most hose turned out to be the culprit. I tightened the clamps on each end and reassembled. Now I just need to wait for a few days to see if it’s fixed. If not I’ll just plan to pull the plenum again and replace the hoses.
  5. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    Replace them all on the entire system. If one goes they are all due for a change. Just saying......
  6. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,220
    CT
    John Kreskovsky
    Must be the ethanol in the coolant. :D
  7. tuttebenne
    tuttebenne F1 Rookie
    Mar 26, 2003
    3,218
    Bay Shore, NY
    Andy
    If those photos are showing green coolant leaking from the hoses I would ask if that coolant is specifically for aluminum engines? I am not aware of one that is green and is recommended for our cars. As for the hose, I agree, if one is getting weak or leaking, there are 10 others that should be replaced at the same time. It takes a good weekend to do it all right but its worth the effort and not too expensive.
  8. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,871
    Mike 996
    "I would ask if that coolant is specifically for aluminum engines? I am not aware of one that is green and is recommended for our cars."
    Any brand of coolant made today is suitable for aluminum engines. The various colors USED to indicate longer-lived coolants of various lengths but nowadays that's not really accurate anymore. IOW, the colors don't matter; any antifreeze you buy is fine for the engine. Standard (green) ethylene glycol antifreeze was typically scheduled to be changed every two years/50k miles; there are coolants now that are designed to be changed every 10 years/300k miles and different brands use different colors for the same spec product.
    Hmm...installing some 10 year coolant will probably be the last time you'd ever have to do it...In 10 years ICE cars will probably be banned from public roads! ;)
  9. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,550
    San Carlos, CA
    Mitchell Le
    I have seen that "leak while sitting" problem on 308. It's normally the old water pump, or the hose connections around the water pump area. The amount of torque needed on those hose clamps makes me feel uncomfortable but that is what it takes.
  10. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Not quite true ... there *are* types of coolant that are not cross-compatible; they shouldn't be mixed.
  11. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,871
    Mike 996
    Good point that I should have mentioned! :( I was just (incorrectly) focused only on the "OK for aluminum" aspect. Thanks for adding the very important point that although they all may be compatible with aluminum, they may NOT be compatible with each other!
