Coolant Leak Won't Stop... | Page 2 | FerrariChat
Discussion in '308/328' started by thorn, Jul 13, 2017.
  1. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,252
    Black Forest Germany
    Martin N.
    I would simply vote for the replacement hose ID being too big. The tube has 40mm OD and your hose 41 ID. I have industrial metric hose here with 40mm ID. It's what I always used and never had a leak problem. And I use the cheapest clamps.
    Best Regards
    Martin
  2. Martin308GTB
    Jan 22, 2003
    4,252
    Martin N.
    Like discussed via PM, John.
    I have just sent you two pieces of metric coolant hose, heavy duty truck and industrial application stuff. Each 100mm long and exactly 40mm ID.
    Best Regards and good luck with it
    Martin
  3. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Thanks again, Martin. I'll let everyone know how it goes. :)
  4. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    #29 thorn, Jul 26, 2017
    Update:
    Emptied all the coolant. Bought a pressure tester kit.
    I replaced the hose in question with true 40mm. (Thanks, Martin!). Also applied some RTV sealant, then got the hose clamped on. Waited 24 hours for the RTV to cure.
    Just ran a pressure test. Can barely get the pressure up to 10psi using a handpump, and it starts dropping to 7-8psi rather quickly. Within a few minutes, it's basically lost all pressure.
    Have tried the "bubble-test" (soaking an area in soapy water, look for new bubbles) and don't see anything significant evidence.
    At this point, I'm just... Yeah. Not in a good way. I've officially spent more time under this car than in the driver's seat.
    Anyhow. So, i guess I'm going to start by replacing the pipe and see what happens. It's only $75 or so. In the image below, I've marked the pipe I believe is leaking. Does anyone know if this can be replaced without pulling the engine out? It appears to be it can, but I want to be sure. Thanks...
  5. wildcat326
    wildcat326 Formula 3
    1,797
    Chicago, IL
    Justin
    #30 wildcat326, Jul 26, 2017
    Thorn -
    Let's try to help you here.
    1) YES, the pipe can be pulled without removing the motor. I'd pull the driver side rear wheel and wheel well liner, and you'll see it's right there.
    2) When I did my resto, I bought a set of "uprated" black silicone hoses. Came as 40mm, but - for love or money - neither me nor my master mechanic who came over to have a look could get them to hold fluid perfectly. I actually got 38mm hoses instead, rubbed a dab of radiator hose grease that they sell for $1 a pack at the autoparts store counter on the inside lip, and - voila - installed.
    3) If you can't get a closed system up to pressure, check your expansion tank cap, which can fail and be barely noticeable. Easily replaced with an uprated version (search here for threads on Stant, or check Superformance.co.uk for a visually similar to OEM higher pressure version).
    4) If you actually have a pipe structurally failing, there's obviously the chance that the same is occurring in the other aluminum pipes. There are five, plus the monster tubes that run through the center tunnel under the car. You could be doing some fishing for answers. BUT...
    5) This system take 6 gallons of coolant, which is ~ = 1 metric crap-ton. Be sure you've drained it thoroughly and don't have air trapped somewhere, which might mess with your pressure testing. I installed an auto-bleeder valve at my radiator. You've got to bleed the hell out of that system.
    6) Failing all else, I actually had to replace this very pipe because my car's previous owner mis-adjusted it, and the clutch tensioner bolt sheared into it. Superformance UK makes stainless replicas, but it turns out there were about four slightly different versions of this particular pipe made (US/Euro/carb/qv etc), and I recall there being a fitment issue. I still have the scarred-up OEM aluminum one in my basement, which can be easily and inexpensively repaired by any shop that can weld aluminum. Happy to mail it to you if you can't find a used one on eBay or Ferrparts, and want to take a shot.
  6. wildcat326
    1,797
    Chicago, IL
    Justin
    #31 wildcat326, Jul 26, 2017
  7. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Hey Wildcat,
    I appreciate your response, lots of good info there. And for what it's worth, it honestly makes me feel a bit better reading that I'm not the only one that's had to chase this demon (obviously I'm not the first, but you know what I mean.)
    First world problems: "My new Ferrari is broken wahhhhh." Sigh. It's just so disheartening. Sorry if I sound like a whiny *****. I've already replaced the deck struts, door gasket, spark plugs and the fuse box, changed the oil - easy, and preparing to clean or replace the injectors. Yay. Done. But this damned coolant...
    I suppose the pressure test has had an upside - i can absolutely hear a "hissss" when I stick my head under the deck, coming exactly from that hose area. Certainly less messy than all that coolant dripping on my garage carpet, for sure. And I got tired of draining it over and over and over. Pretty sure my local dump is going to freak out when I show up with 1,296 gallons of used coolant to recycle....
    Anyway.
    When I was testing with coolant in the system earlier this week, i never saw fluid weeping from the top of the hose - always from the bottom. Since I've used a long 41mm hose, and a shorter 40mm hose with RTV (and new clamps, tightened multiple times), i'm thinking it just has to be the pipe (as others earlier advised.)
    I found the part (i think) on Ricambi. I'll call them to be sure though. I'm also going to get a couple hoses made by Scuderia Rampante; I've read a lot of good things about them.
    That top pipe of yours looks pretty close actually - maybe save it for another week? I may need to send you some $ if vendor sources don't work out. ;)
  8. wildcat326
    1,797
    Chicago, IL
    Justin
    Dan at Ricambi is a good and honest person to deal with. They offer excellent service, but occasionally their site will show a NLA part as available, and your order will be canceled. Also check with them to see if their replacements are aluminum or stainless steel, if that matters to you. The pipes don't actually contact each other inside the connecting hoses, but some worry about using dissimilar metals in the system. Ferrparts is a great go-to for used salvage parts if you can stomach their worst-in-class customer service and attitude.
    I used SRI kits for fuel and coolant hoses. They provide the correct and best clamps, but we actually sent back their "standard" 308 coolant hose kit and requested 2mm smaller for the pipe hoses, which they had available for other models. Solved the problem, but don't forget the lube while installing.
  9. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Ooooo, didn't that about re: NLA. Thanks for that info.
    Yeah, I'd be ok with the pipe being aluminum, stainless, PVC, or sausage casing at this point. ;)
  10. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    #35 thorn, Jul 27, 2017
    Floor took a slight coolant bath again... but pipe is out. Was easier than I expected. Removing the heat shield made the access quite easy. I'll clean that shield up while I'm at it. Nasty dirty....
    Don't see any obvious flaws (edit: I take that back. there's a slight rub/indention at the middle bend. But it wasn't leaking from there.) No big cracks, but oddly I'm feeling just a slight bit of optimism. At least it seems like I'm doing something besides tightening a clamp for the 23rd time in an hour. And draining coolant.
  11. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    After a flush with water, pucker up and suck hard on any suspect areas (or dish soap and blow into one end with a compressor while blocking the other end.) hope it's this pipe!
  12. Saabguy
    Saabguy Formula 3
    1,784
    Shreveport, LA
    My thought exactly, the blow not the suck. Tape up an end and submerge and blow.
  13. tinterow
    tinterow Formula 3
    Nov 1, 2014
    1,339
    Houston, Tx
    Chaya Tinterow
    I don't remember you identifying "exactly" where the leak was coming from. Inspection mirror and contortions are necessary! Disassembly isn't gonna solve your problem unless you get lucky, such as this pipe is the culprit. That pipe looks fine, even with it's little flaw. You will end up replacing it which is fine, but you might still have the leak. You have to find that leak on the car before continuing, unless you want to remove all coolant related parts in the area of the leak. Then if it's not obvious to the naked eye, you still have to recreate pressure. Not easy when parts are off the car. Just sharing a little shadetree experience. :)
  14. tinterow
    tinterow Formula 3
    Nov 1, 2014
    1,339
    Houston, Tx
    Chaya Tinterow
    We chased down a coolant leak for days one time. The stuff likes to flow around and give false positives related to the leaks exact location. Turned out to be the pump! Exactly where you would think it would be, but for some reason it just didn't seem like that's where it was. If we would have started disassembling where we "thought" the leak was, we would have wasted a lot more time. You need the car to be running in "real world" condition to chase those pesky leaks! Start the car, inspect for leak, when you see coolant, rinse and repeat until you narrow it down.
  15. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    There were 4 different ways I've come to this conclusion.
    1. The drip-drip was coming from the connection of the hose to the pipe. I crawled under the car (while it was running and warm) and saw it dripping from the bottom of the hose.
    2. Head under the deck, noted no green wetness coming from the top of the hose. Shop towel dabbing on top hose/pipe connection didn't start getting wet.
    3. Tightened the bottom clamp, while car was running and warm. Leak got worse, from drip-drip to "oh, you want me to leak more?" The more I tightened the worse the leak got.
    4. After replacing hose and using RTV, used a pressure tester (air) with coolant drained (except in the engine block.) At 8-10psi, I could hear a hisssssssss in my left ear, when I stuck it under the deck and as close to the hose as I could get. I guess I could put another 6 gallons of coolant in the car and bring it up to temp again, but I suspect I'd just see it dripping out of that same place again... as that's what's happened with the last 3 hose changes.
    Certainly there could be some OTHER area in the system that has a leak - under the battery, the waterpump, etc - but those areas aren't near the steady drip I'm visually confirming.
  16. 308 milano
    308 milano F1 Veteran
    Jan 15, 2007
    5,306
    Montana
    Kim
    IIRC, my car holds 2 1/2 gallons coolant completely dry. You're able to put 6 gallons in your system???
  17. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    LOL, no... was just humor. ;)
    "Since I couldn't find a leak, I've upgraded the expansion tank to a 22-gallon unit from a semi truck. So while it leaks, I can at least drive for about 30 minutes until it all runs out. Then I refill with with the drum of Prestone riding along in the passenger seat."
  18. Saabguy
    Saabguy Formula 3
    1,784
    Shreveport, LA
    You are 90% done with the diagnosis although it will be a hassle now. You need to do the old fuel line to the ear trick. Pressurize system until you hear the hiss then fuel line to ear and use the open end to move around and locate that hiss exactly. I have had leaks that I was sure from component x only to find that under pressure component z was squirting very fine stream onto x. And I could even argue that by tightening the connection you were keeping excess pressure from leaking so that the pressure available for the leak increased.
    Or maybe it is the pipe. Duct tape off one end, dry throughly, fill with water and food coloring. Locate leak.
  19. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,763
    Cerritos, CA.
    Or you could find a way to catch the leaking coolant and recycle it while driving. :D
  20. tinterow
    tinterow Formula 3
    Nov 1, 2014
    1,339
    Houston, Tx
    Chaya Tinterow
    #45 tinterow, Jul 27, 2017
    Exactly!!! That stuff loves to run along creases and down pipes...you have to find the source before any more disassembly...and you will! Either put this pipe back on or replace it...refill system, heat up the car and keep searching...you will find it! You must follow the coolant, even where you think there is no way it could be the source. :)
    P.S. You don't have to use "any" coolant to test for leak...the green just makes it a little easier...put some food coloring in it! :)
  21. wildcat326
    1,797
    Chicago, IL
    Justin
    Just consulted the manual, which specifies ~5 gallons for the system. I was off by a gallon. Then it came back to me; the reason I said 6 is that I mixed up a batch of 2 gallons of antifreeze to four gallons of distilled water when I filled it. But yes, this car takes a LOT.
    My Jeep recently took less than 2 when my water pump failed and everything emptied through the overflow hole.
  22. tinterow
    tinterow Formula 3
    Nov 1, 2014
    1,339
    Houston, Tx
    Chaya Tinterow
    Hiss? Turn off all accessories! Hiss = Steam...Has to have moisture related. Go to any parts store and get a stethoscope. $10! And an inspection mirror or one of those $50 gizmos with a little screen. That will narrow it down...You'll find it!
  23. wildcat326
    1,797
    Chicago, IL
    Justin
    #48 wildcat326, Jul 27, 2017
    One assumption I've had from reading your posts is that you were CERTAIN that the pipe or hose is the source of the leak.
    Some other areas to look at would be:
    - The water pump (both mating seal and the nipple that connects to the long skinny hose, which can corrode). Very easy for coolant to travel stealthily in the engine "vee" to the driver side and drip down, which happened to me on startup when we replaced that corroded nipple and the threads of the new one didn't match up correctly.
    - There also is a heater hose nipple on the rear bank cylinder head (driver side) that can - and usually does - badly corrode over time. The long heater hose that runs through the driver door sill hooks up there. CAUTION: If you find this to be the culprit, the nipple screws into the head, despite appearing to be cast into it. Uprated replacements are under $100 (Ricambi shows the stock for $7), but HAVE A PRO EXTRACT THE OLD ONE. You're in for machine work pain if something goes wrong.
    - If you look down with a telescoping inspection mirror and flashlight, there also are two rubber connector hoses on the pipe that sits down in the engine vee between the water pump and the pipe you currently think is problematic. It's hard to access and thus seldom serviced properly with the rest of coolant pipes/hoses.
  24. mikael82
    mikael82 Formula Junior
    Nov 18, 2007
    869
    Finland
    Mikael
    #49 mikael82, Jul 27, 2017
  25. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    One thing on that: when I heard the hiss last night, the car was empty of coolant and cold (haven't started it in a couple days). I was pumping on the air pump (pressure tester) like a madman... around 8-10psi, you could hear it leaking air down there. Sounded kind of like a leaky tire.
    So wasn't steam (in this moment), just cold air passing through something it shouldn't.
