Coolant Leaking 87 Testarossa - Help! | FerrariChat
Discussion in 'Boxers/TR/M' started by sohailrashid, Aug 19, 2016.
  1. sohailrashid
    sohailrashid Karting
    Jun 18, 2005
    105
    San Jose California
    testacalvo
    1. Please watch the video.
    https://www.dropbox.com/s/3o8suorj947m6jc/MOV_0874.mov?dl=0
    2. The leak seems to be underneath. The coolant tank has a few rust spots and also seems wet.
    3. The car was stored in my garage for almost 10 months as I was overseas. I started it last week and drove it around. It drives well.
    4. This morning when I started the car I noticed the puddle on the garage floor and then the drip.
    5. The car is due for a major. The last major was in 2011.
    6. Hope its nothing serious.
  2. rpissm
    rpissm Formula 3
    Aug 11, 2013
    1,620
    Salt Lake City, UT
    Joe
  3. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    If that gets worse i would bring my shower gell.
  4. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,528
    romano schwabel
    that is not the waterpump
    I think the right cylinderbank where the hose is going to the Y connection it is leaking
    check there first please.
    or one of the temperature sensors is broken?
    when you look up you see from where the water is coming?
    mike: shower gel and antifreeze is terribel ! ! ! :(
  5. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    You never know i might like that particular mix , sounds like u have tried it already. Is your skin still aqua blue.
  6. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Likely it is either the wp or heater hose.
    Since it is time for a major, don't mess with it - just do the major. Don't drive it - ship it.
    Likely no additional expense beyond a 'typical' major. Breathe easy.
    Rgds,
    Vincenzo
  7. Mr.Chairman
    Mr.Chairman F1 Rookie
    Mar 21, 2008
    2,987
    New Jersey
    Robbie
    Agree
    R
  8. carguy
    carguy F1 Rookie
    Oct 30, 2002
    3,424
    Alabama (was Mich.)
    Jeff
    I agree with Romano....this is a hose issue. There are several hoses above this area, the large hose going to the water pump, the hoses near the top of the engine going to the "Y-shaped" manifold, and heater hoses. It could be any of these, you need to get under the car and look upwards in that area. That leak is pretty big so you should not drive the car like that. Bad water pumps will usually have a slow drip, not anything close to this leak.
  9. sohailrashid
    Jun 18, 2005
    105
    San Jose California
    testacalvo
    Thank you for your help guys. I agree that I should get the major done before I attempt to drive it again but in the meantime I would like to troubleshoot the issue.
    I re-filled the expansion tank and started the car again (so I could roll up the windows) and the drip is gone. Even with the car running for five minutes the drip is not happening.
    Whats going on? If its a bad hose then shouldn't it keep leaking?
  10. turbo-joe
    Apr 6, 2008
    9,528
    romano schwabel
    may be when the car i sstanding longer time and the hose gets hard when first time pressure comes on it till leak where the hoses are attached to the aluminum tubing with hose clamps. check wether the clamps are tight
  11. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Good point - agreed.
    Vincenzo
  12. rpissm
    rpissm Formula 3
    Aug 11, 2013
    1,620
    Salt Lake City, UT
    Joe
    Yeah you only ran it for 5 mins. Did the fans come on? If not then you didnt get it hot enough to see if it leaks under pressure.
