Coolant leaking out of overflow tube | FerrariChat
Discussion in '206/246' started by need4speed, Oct 8, 2015.
  1. need4speed
    need4speed Formula 3
    Nov 3, 2003
    1,616
    Pacific Palisades
    Hey Everyone,
    I recently repaired my header tank. But now I have a new problem. I found another owner with the exact same issue in this old post. But because it is an old post, I thought I'd post a new one.
    http://www.ferrarichat.com/forum/206-246/255105-coolant-leaking.html
    My car is running fine. But when I come home at night, I had to idle in the drive way while I removed my son's bike. After I had parked the car, I noticed a puddle of coolant on the drive way where I was idling. And a trail up the street. I found that it was coming out from the overflow tube. My coolant level is not too high. Why would coolant be running out?
    Any ideas much appreciated,
    Manny
  2. racerboy9
    racerboy9 F1 Rookie
    2,650
    Your radiator cap may be the wrong one, defective or not rated for the correct pressure. I don't know the correct pressure off hand but should be an easy check on the forum search function.
  3. need4speed
    Nov 3, 2003
    1,616
    Pacific Palisades
    So it may have become defective? Because I've never had an issue before. Do radiator caps "break"?
  4. BigTex
    79,380
    Houston, Texas
    Bubba
    They certainly lose spring pressure over time, and it was found on the 308s that a one step higher spring pressure was optimum.
    So yes, all the OEM ones on our cars in the V8 section should be uprated...a search will find the rating. 1.4BAR, from memory...:D :D
    14 -16PSI, up from 12???
  5. Pantdino4
    Pantdino4 Karting
    Sep 17, 2015
    184
    Los Angeles
    Jim Oddie
    1 bar = 14.7 psi, so the 0.9 bar cap, which I believe is correct, is about 13 psi.
    1.4 bar = 20.6 psi, which I believe the system was never designed for. I totally don't recommend that.
    When you say your header tank is "not too full," what do you mean? It should only be like 2/3 full to allow for expansion of the coolant. You probably have too much in it.
  6. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Manny,
    The radiator cap is a spring and weakens over time, you'd be surprised how important it is because a new cap can actually assist in engine cooling
    I found a two eared Murray brand at O'Reilly's and was impressed when temps declined
  7. need4speed
    Nov 3, 2003
    1,616
    Pacific Palisades
    Hi Guys,
    So I'm looking for a 13psi cap?
    PantDino, my coolant level is about 1.5-2" from the cap.
    Manny
  8. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    I had exactly the same last year and found the radiator cap under the rubber seal had cracked.
    Peel back the rubber and check for cracks in the metal.
    Always worth buying two and keeping one in the boot as a spare.
    1bar = 14.50psi absolute
  9. need4speed
    Nov 3, 2003
    1,616
    Pacific Palisades
    Hi Tony,
    Am I looking for a 1 bar cap? Or was that just an easy conversion factor?
  10. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,799
    Southern California
  11. Dino246gts
    Dino246gts Formula Junior
    434
    Is it possible that just idling in the driveway was enough to heat up the fluid a little more than usual, expand it a little more than usual, so it drained? I've had the same thing happen. Drive the Dino on a cool day.....no overflow. Hot day......overflow. However, next hot day....no overflow. It's as my the Dino knew just how much fluid to drain from itself so it wouldn't overflow on the next hot day. Smart car! Or.......I'm just dreaming.
  12. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    #12 TonyL, Oct 9, 2015
    A 0.9 bar cap (13psi) is more than adequate for the 246 imho. Remember the cap is just a safety release if the pressure within the system expands beyond the design pressure. Its not there to regulate the pressure.
    The expansion tank accepts the increased volume of water at full operational temperature (0.8 litres approx.) from the lower hose connection and must have at least 5cm (2") of air cushion at the top, I run my at about 8cm. The tiny top hose is there to collect steam and condense it back and also for vacccum release when the system cools down.
    Water discharged from the overflow hose can be a number of causes but commonly its either the cap that's defective or there is not enough air cushion left at the top of the tank i.e "overfiiled"
    A fully bled system is desirable to increase efficiency expansion and cooling but not critical, the system is well oversized for the heat generated from the engine under normal operating temps. The most noticeable areas for airlocks are the heater matrixes and these can be bled locally via the hoses.
    In all cases do not cook the engine.
  13. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,638
    Toronto / SoCal
    Rob C.
    Excellent reply. Very informative and spot on
  14. Pantdino4
    Pantdino4 Karting
    Sep 17, 2015
    184
    Los Angeles
    Jim Oddie
    More boring than a thinking car, but same effect- the system ejected the amount it was overfilled. When the system cooled again the coolant volume decreased and you should have the correct amount in the header tank now.
    But a little "less than perfect" = no problems. A little "more than perfect" = spits out coolant.
    So a little less is better than a little too much.
