Coolant level 360 and small leak | Page 2 | FerrariChat
Discussion in '360/430' started by kimpearsonusa, Apr 13, 2014.
  1. Rifledriver
    36,882
    Anything called "Ferrari Coolant Service" is a joke. Their service schedule for the cooling system and transmission oil is a very direct cause for the heat exchanger failures. Anyone not ignoring Ferraris service schedule for both is a failed heat exchanger waiting to happen.
    The service schedule does say to pressure test the system at services but few dealers ever do. As I recall Ferrari does not even supply a tool to facilitate doing it. The dealer service department I ran I had to buy the adaptors from an outside source and every car was tested.
  2. Zcobra1
    Zcobra1 Formula 3
    1,242
    So Cal
    Bert
    AW auto parts has the caps for $39. Anyone deal with them ?
  3. up4speed
    up4speed F1 Rookie
    3,650
    Long Island, NY
    Chris
    I used them once. They had a great price on the alarm module ($255).
    Everything went smoothly and the price was great, so I have to say they are good.
  4. Zcobra1
    Zcobra1 Formula 3
    1,242
    So Cal
    Bert
    Thanks for the input. BTW, good deal on the alarm, it is $325 now......
  5. up4speed
    up4speed F1 Rookie
    3,650
    Long Island, NY
    Chris
    I saw that they raised the price almost a year ago (I purchased mine ~15 months ago). It made me wonder if they had "old stock" with old/weak batteries in it? Still works great, so I'm probably ok. If it fails again, and I catch it quick enough before the battery leaks, I may do the surgery that lets me use an external (replaceable) battery.
  6. English Rebel
    English Rebel Formula 3
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    Look like the OEM unless you know different.
    Alan
  7. KILOCHARLIE
    KILOCHARLIE Formula Junior
    Oct 14, 2012
    321
    Cardiff, UK
    KC
    Just checked my cap and its shot to pieces! Rubber seal broken and the white plastic cap is hardly being held on :(
    Checked for a replacement and eurospares is quoting a special order item which basically means up to two weeks wait. Am I safe to drive my car during this period at all? It it more important to seal the expansion tank when the pressure builds up or is it more important to allow air in when it cools? Really wanted to use the car this easter weekend.
  8. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    Hi Brian - are the heat exchangers on F430's prone to failure as well? I believe the design is different.
    I have my coolant and transaxle oil changed annually in any case as it is cheap insurance.
  9. mello
    mello F1 Veteran
    5,471
    CA Bay Area
    Steve
    #34 mello, Apr 18, 2014
  10. London
    London Karting
    Aug 29, 2009
    189
    London
    #35 London, Apr 19, 2014
    Since we're talking about these caps maybe someone can shed some light on the following. I replaced mine as well last year on my 360 spider, just as a preventative measure. I ordereded the replacement from Eurospares here in the UK, which says something strange: the tank plug (which is the same for a wide range of Ferrari models, from the 550 to the 458) is listed as being superseded by a Maserati part:
    http://www.eurospares.co.uk/searchResult_one.asp?M=&Mo=&A=&B=&ID4=&S=145030&SO=1&SB=3&SM=&SMo=&O=10
    The original Ferrari part is 145030, the Maserati one is 374030103. I also spoke to Eurospares on the phone and they confirmed it. I ordered the Maserati part and indeed it looks very similar, but it is stamped "0.90" instead of "1.00" of the original, which makes me think it's rated at a lower pressure. Do you think this is a problem?
  11. English Rebel
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    Thanks for that information Steve. I'm going to order one.
    Alan
  12. Skidkid
    Skidkid F1 Veteran
    9,500
    Campbell, CA
    John Zornes
    Didn't we start a sticky thread for parts cross reference? Maybe that was a different section. If not we should and we should add things like this cap to the thread.
  13. fiat
    fiat Karting
    Aug 5, 2012
    80
    florida
    graziano
    If you take the cap off you will see that the inside the thank will have two lateral cuts extending about two inches into it, as you add coolant it will come into contact with this slots and it will cause the coolant to take an oval shape, same as adding fluid to older type batteries, which had similar slots cut into it to keep from overfilling. stop filling when you see the above mentioned conditions. just my 2cents worth.
  14. fiat
    fiat Karting
    Aug 5, 2012
    80
    florida
    graziano
    easy way to tell if your cap is bad, just keep an eye on your temp gauge ,if the cap is bad the temp will register on the high end of the gauge. the cap is basically a radiator cap need to keep the proper pressure in order to keep the temp at bay. if the pressure goes to high there is not catch tank, it will dump the fluid into the left bottom under tray. just my 2 cents worth.
  15. KILOCHARLIE
    Oct 14, 2012
    321
    Cardiff, UK
    KC
    Would be grateful if anyone knows of a cross reference part for here in the UK. Need on badly and all suppliers a quoting me weeks to receive one. I did read somewhere that its the same cap as a Nissan Micra(!) but can't confirm it. Anyone with any insight, please post!
  16. kimpearsonusa
    kimpearsonusa Rookie
    May 18, 2011
    37
    Lake St. Louis, MO
    Kim Pearson
    #41 kimpearsonusa, Apr 19, 2014
    OK I just got home from a 4 day trip and my replacement pressure cap is here. When I started this thread I would have a small amount of coolant on the side of my engine pan where the overflow hose went.
    I thought it might be over filled and would find the right level over time, as my tank was a little less that 1/2 full. Anyway after a year or so the tank was empty when the engine is cool. When I ran the engine some and slowly bleed off the pressure (which is how you check the system when it is hot) I had coolant in the tank again up about 1/2 inch from the bottom. After it cooled down the tank was empty again.
    My old cap doesn't look that bad compared to the new one. Here is a picture. The new cap came in a Ferrari box has the white rubber. My old cap is the black one on the right.
    Going to go drive the car now and see if it helps.
    Kim
  17. mello
    mello F1 Veteran
    5,471
    CA Bay Area
    Steve
    You're right. According to the manual, the coolant level should be checked when the engine is cool and the level should be 40mm from the top of the neck. I measured distance from the top of the neck to the bottom of the slot and it came to be about 38mm. Close enough.
  18. mello
    mello F1 Veteran
    5,471
    CA Bay Area
    Steve
    This is my uneducated guess, so accept it for what it is worth.
    1.00 bar is 14.5 PSI which equates to about 220F boiling point of water.
    0.90 bar is about 13 PSI which equates to about 205F boiling point of water.
    I gathered in the above calculation that you'll be fine if your driving temperature falls within that range.
    Is there a physicist in the house that could give us a definitive answer?
  19. London
    London Karting
    Aug 29, 2009
    189
    London
    The Eurospares website says they have the "equivalent" Maserati part in stock - as I said, it's not identical but I've been running it for a year on mine and it seems to be working fine...
  20. up4speed
    up4speed F1 Rookie
    3,650
    Long Island, NY
    Chris
    Boiling point of coolant is higher than the boiling point of water.
  21. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    Try Steve Holdsworth @ Joe Macari. He has 5 deliveries a week from the factory and can get his hands on pretty much any part.
    If you really are desperate I think I have a used one on the shelf somewhere - happy to lend it to you until you get a new one. PM me.
  22. KILOCHARLIE
    Oct 14, 2012
    321
    Cardiff, UK
    KC
    Thanks Voicey (and London), I might take you up on that offer if I have no luck but will speak to as many people as I can on tuesday first and send you a pm as a last resort. Thanks though. The maserati one is a great tip too. Hopefully I can get one by next weekend at the latest and the weather will stay like this so it doesn't make me feel as bad as it did last week! Thanks again.
  23. MortgageRockstar
    Feb 8, 2013
    99
    Mansfield, MA
    Geof
    Great info.
    Where specifically did you purchase this?
    I tried searching on Google and could not come up with an online source.
    Thanks in advance for your help!
  24. 993turbo
    993turbo Formula Junior
    Oct 4, 2006
    317
    Puerto Banus
    Remi E
    Do a FleaBay search.....
  25. MortgageRockstar
    Feb 8, 2013
    99
    Mansfield, MA
    Geof
    Thanks. I already did that, but there was only one listed and it was an auction.
    I'm looking for an actual supplier that I can order from.
    Anyone?
