Coolant Level? | FerrariChat
Coolant Level?
Discussion in '308/328' started by Speedracer33, Jul 18, 2014.
  1. Speedracer33
    Speedracer33 Karting
    Jul 17, 2012
    161
    Philadelphia Area
    Matt B
    Sorry for the elementary question, but should the coolant level (in the rear tank) be all the way up to the top? I don't want to overfill and have it throw up when it gets hot....
    This is for an '85 QV in case that matters. Thanks.
  2. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,872
    Mike 996
    It's an expansion tank so NO. If you fill it where there is no room for expansion, it will just spill overboard when the coolant heats up. If I recall, Ferrari says 5 or 6 cm below the top.
    Actually, there is no need to worry about it at all. If you fill it too much, it will just spit out over a few trips until it reaches the correct level and will be fine after that. As long as there is some coolant in the tank when cold, there is enough in the system.
  3. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,149
    SanFrancisco BayArea
    1983 US 308 GTS QV
    Check the owners manual. I believe the spec is 6 cm below the top of the neck. Make a dipstick with a line at the 6 cm point. I was overfilling until I realized just how low in the expansion tank 6 cm really is: it looks less than half full.
  4. Speedracer33
    Jul 17, 2012
    161
    Philadelphia Area
    Matt B
    Based on that, it sounds like I'm about right. Thanks guys, much appreciated!
  5. spirot
    spirot F1 World Champ
    Dec 12, 2005
    15,121
    Atlanta
    Tom Spiro
    rule of thumb is : coolant when cold just over the seam on the expansion tank.
  6. Ehamilton
    Ehamilton F1 Rookie
    2,641
    Durham, NC; USA
    Eric Hamilton
    A really easy check that I learned from an experienced tech: Stick your index finger down into the tank. If you can touch coolant, you're good.
    And at the risk of stating the obvious.... You do this on a cold engine.
  7. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,811
    Cerritos, CA.
    Just fill it up half a tank and you're good to go.
