Coolant overflow tank removal? PLEASE HELP | FerrariChat
Discussion in '308/328' started by andrews308, Jul 15, 2014.
  1. andrews308
    andrews308 Rookie
    May 4, 2014
    46
    Cleveland
    Andrew D.
    Can anyone tell me if there is or what is the easiest way to remove the coolant overflow tank?
    I want to take it out to have it repainted- but I need to know what steps are involved to do so.
    Thanks in advance!
  2. MNExotics
    MNExotics F1 Rookie
    2,631
    Good Thunder
    Ben Gruenzner
    Drain it
    Disconnect the hoses
    Disconnect any accy wires or vac tubes
    Unbolt and it's out
    I have a dedicated coolant extraction tank I use for draining the system
  3. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    The rear mount itself unscrews from the rear bulkhead. There is no nut in the trunk space to remove. Don't ask how I found this out if you plan on replacing it as it tends to rot out.
