coolant pipe airbox interference | FerrariChat
Discussion in '308/328' started by jrinehart, Aug 23, 2010.
  1. jrinehart
    jrinehart Formula Junior
    Jan 30, 2009
    578
    Chambersburg, PA
    John Rinehart
    I saw this on Ferrari documentation http://ferrari.cdyn.com/ I was going to do it this summer but it was darn hot this summer so I chose to do it in the fall. I went for a drive end of July and saw coolant in the garage checked it out and found the coolant pipe leaking at the airbox which was rubbing on the pipe. I had Competizione look at it and had it welded since this part is NLA. Any 328 owners should have this area checked and also the interface between the frame rails and anywhere else this pipe could rub and put a piece of old hose clamped over these areas to prevent the pipe from rubbing. Hope this helps others from down time. The site listed above gives some good instructions on other maintenance and rifledriver has also contributed to this information for a couple of areas. The car is back to running good with no leaks. Time for a drive!! See ya on the road.
