Coolant Recommendations | FerrariChat
Discussion in 'Boxers/TR/M' started by txav8er, Aug 11, 2009.
  1. txav8er
    txav8er Rookie
    Jan 30, 2008
    28
    Austin, TX
    Can anyone rec. a brand of Coolant for my 87 Testarossa? Mine looks a little low. What mix should I use?
  2. irondogmike
    irondogmike F1 Rookie
    Sep 8, 2006
    2,532
    San Diego area
    Michael Tucker
    redline water wetter + water + 50/50 prestone = temp 30* cooler
  3. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    You lost me there Michael
  4. lasvegascop
    lasvegascop Karting
    Apr 12, 2009
    222
    Las Vegas, NV
    "Ski"
  5. Jeff Pintler
    Jeff Pintler Formula Junior
    Jul 20, 2005
    537
    Richland
    Jeff Pintler
    Another coolant is the stuff Mercedes sells. There was some mention in the National Mercedes Club magazine that Prestone was NOT to be used in their cars. And my data point has been no corrosion buildup in 25 years in 8 cars and specifically 2 f cars over 8 years. The independant that did my last 348 major wanted to know what I used because of how little corrosion present. FWIW
    Jeff Pintler
    89 348tb, 86tr
  6. lasvegascop
    lasvegascop Karting
    Apr 12, 2009
    222
    Las Vegas, NV
    "Ski"
    AKA..... Zerex G-05
  7. tazandjan
    39,176
    Am running the Zerex in my 575M. Good stuff. Just about everything slippery in my car is Valvoline and it all works great.
    Taz
    Terry Phillips
  8. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    I use prestone 70/30 with distilled water.....max cooling efficiency mix according to the instructions on the container.
    Every time I flush the coolant ( once a year ), I fill with distilled water and run the prestone flush cleaner. I drive with that a few days, drain out, then refill with coolant.
    You won't believe the color and stuff that comes out when you started with a clear cleaner and distilled water.
    Shamile
    Freeze...Miami Vice !
  9. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    I'm always willing to try new things.
    ......I wish the girls I know thought the same. :D
    Perhaps that's why I get a bit of crud even though I change coolant once a year....hmmmm
    Shamile
    Freeze....Miami Vice !
  10. lasvegascop
    lasvegascop Karting
    Apr 12, 2009
    222
    Las Vegas, NV
    "Ski"
    hahahahhah!!!
  11. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    I run that in my BMW's. Much easier on the plastic components in the cooling system.
  12. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    I run BMW coolant in my BB512i ...30% coolant - 70% distilled water
  13. irondogmike
    Sep 8, 2006
    2,532
    San Diego area
    Michael Tucker
    one bottle of water wetter,about two gals of coolant mixed 50/50,and top the rest with water,when done my car ran 30*f cooler
  14. Forexpreneur
    Forexpreneur Formula Junior
    May 11, 2009
    638
    Portland, OR
    Alexander Everhart
    That is a big difference in temps. Thanks for sharing.
  15. lasvegascop
    lasvegascop Karting
    Apr 12, 2009
    222
    Las Vegas, NV
    "Ski"
    #15 lasvegascop, Sep 9, 2009
    OK...took the plunge and went with the recommendations of this thread!! I drained the system, refilled it with pure distilled water...ran the engine with heater on full. Drained it again then filled it with two bottles of Prestone coolant flush...ran that for about 60-70 miles (3-4 days worth of driving), drained that and finally refilled it with distilled water, 1 gal of Prestone Dex-cool (orange in color) and bottle of Water Wetter.
    Guess what? With temps here in Vegas in 110 deg F, this set-up really works perfectly! Before with regular 50/50 my temp gauge was close to the middle with the fans running almost constantly. Now, the fans do kick in but the temp sits almost at 1/4 of the gauge.
    It's definately transferring the heat better and at the same time, it gets rid of it in a snap. If it works in Las Vegas, it has to work anywhere else! hahahha
    Sooooo....thank you for your input into this. It really makes me drive my car with great confidence
    Ski
