360 - Coolant Recommendations | FerrariChat
360 Coolant Recommendations
Discussion in '360/430' started by Dino6304, Jan 28, 2021.
  1. Dino6304
    Dino6304 Formula Junior
    Jul 27, 2020
    537
    CT
    Laurence
    Likely asked many times
    What coolants can I use with my 2002 Modena.
  2. imahorse
    imahorse F1 Rookie
    2,773
    WI
    Dustin
    I run Zerex G05 and have had no issues. I'm sure there is some better option somewhere before the coolant police come after me
    jcurry and hessank like this.
  3. Dino6304
    Jul 27, 2020
    537
    CT
    Laurence
    Likely a reasonable choice
    Let’s see what others recommend
  4. timwu12
    timwu12 Formula Junior
    919
    TX
    zerex g05 for me as well
  5. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,680
    Central NJ
    Dominick
    I used to be in the g05 camp but now after research i am in the G48;camp
    Sent from my moto g(7) using Tapatalk
  6. hessank
    hessank Formula 3
    1,747
    Canada, Florida
    Fred
    Me too for the G05.
    However, it is not a 'true' long life (5 years) coolant so I flush mine every 3 years (I used to do it every 2 years during my first 4 years of ownership).
    The best one (OE recommended????) is Shell Rotella ELC or CAT ELC (not to be confused with Shell ULTRA ELC).
    For my last coolant change (Nov 2020) it was nowhere to be found in Canada
    “Shell Rotella ELC is a "fill for life" ethylene glycol-based coolant for heavy-duty diesel, gasoline and natural gas-powered engines. Shell Rotella ELC contains a unique extended life carboxylate inhibitor system and nitrite/molybdate as secondary Shell Rotella ELC meets all the requirements for CAT EC-1, TMC RP 329 and RP 338
    o Improved water pump seal life due to low dissolved solid levels
    o Excellent heat transfer
    o Reduced overall coolant and cooling component maintenance”
  7. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,680
    Central NJ
    Dominick
    Oem fill and recommended is g48
    The shell you mentioned has been some mechanics here and now the new formula is she'll elc nf
  8. hessank
    hessank Formula 3
    1,747
    Canada, Florida
    Fred
    This is a quote I copied from 15 years ago when I first joined FChat. Not sure who wrote it here.
    · What does my Ferrari require?
    a) Must be free of Phosphate and Silicate and must have Nitrites for the wet cylinder liners to prevent liner cavitation erosion. The BMW grey/green coolant, Shell Glycoshell and Valvoline Zerex G48 all have no phosphates. Mercedes and BMWs do not have wet liners, so G48, Glycoshell or BMW grey/green without Nitrites works well for them. However, the Ferrari 360, 430 & 550 engines also need Nitrites and those 3 do not have Nitrites. Valvoline Zerex G05 is HOAT Technology and is recommended for Ferrari but it is not a true long-life coolant.
    Type of coolant has always been and continues to be a contentious issue here.
    Hence, my belief in what was written above
  9. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,680
    Central NJ
    Dominick
    #9 flash32, Jan 28, 2021
    Newer coolants in including the new shell include different chemicals to protect cylinder liners
    The G48 is called for by some diesel engines with liners
    Look at the approvals
    Things have come a long way
    Look at shell elc nf ..no nitrite and made for commerical trucks
    That all being said I don't think you can go wrong with G05 - the reason I left the G05 camp was some concerns with it attacking some heat exchangers with 360 already have had some issues
    hessank likes this.
  10. hessank
    hessank Formula 3
    1,747
    Canada, Florida
    Fred
  11. tazandjan
    38,082
    #11 tazandjan, Jan 28, 2021
    hessank likes this.
  12. hessank
    hessank Formula 3
    1,747
    Canada, Florida
    Fred
    G05 is also readily available at every auto store.
  13. tazandjan
    38,082
    Fred- G48 is readily available too, but I prefer the G05. It was not, in the past, a coolant for those who wanted it to last several years since the additives only lasted a couple of years. Since I changed it every 2 years, no problem. Now GO5 has nitrited HOATs, so not sure how long it will last. I will still change it every 2 years.
  14. hessank
    hessank Formula 3
    1,747
    Canada, Florida
    Fred
    Thanks. I'm doing 3 years now too
  15. tazandjan
    38,082
    If I had a 360, I would change it annually just to make sure the heat exchanger had not taken a hike.
  16. hessank
    hessank Formula 3
    1,747
    Canada, Florida
    Fred
    Actually Terry when I bought my car here was no maintenance history. So as part of the major I had the WP, Thermostat, all sensors and HX & coolant replaced.
    That was 2014. The next 3 years I continued flushing the system annually until a few folks here told me that was overkill. So I went to 3 years and last Nov before the big sleep I did one of those complete flushes (Black360's version) with Zerex G05
  17. fotostars
    fotostars Formula Junior
    Feb 6, 2015
    341
    Bay Area
    Link to Black360 flush procedure? I did a search but couldn’t find it
  18. hessank
    hessank Formula 3
    1,747
    Canada, Florida
    Fred
    Here you go
  19. Skippr1999
    Skippr1999 F1 Rookie
    4,216
    Mercedes Benz blue stuff. Apparently good for 5 years minimum per trusted mechanic.
    Used to use G05 every two years.
  20. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,680
    Central NJ
    Dominick
    MB BMW and g48 pretty much the same
  21. Skippr1999
    4,216
  22. janmante
    janmante Karting
    176
    jan mante
    Well to be completely different has anyone tried Evans waterless?
    we are considering it !
    It is in use by over 1.5 million users ! w/ No credible reported issues
    it is a real lifetime coolant and used by many racers Jay Leno converted over 200 of his cars i understand !
    as it has NO water it will not cause erosion, corrosion , wear,it does not pressurize and as it boils at 375 Deg F it will never boil ! it would stress the cooling system much less .
    it is said to cool much better and cavitation is virtually impossible .
    Yes, it is very expensive and converting a vehicle to use it is a bit of a PIA the $ should hardly be an impediment to Ferrari owners .
  23. hessank
    hessank Formula 3
    1,747
    Canada, Florida
    Fred
    I did some research a while back and here was my summary:
    Executive Summary: Even with the advantages I'm way too chicken to try this.
    Advantages:
    (1) One big positive is electrolytic corrosion is no longer an issue
    (2) Evans is unique in that it does not require pressure to raise the boiling point, that reduces the stress on older systems
    (3) Since it boils at 375 Deg F overheating (engine) should not be a problem
    (4) No more Thermostat failure as that piece of equipment gets removed (Evans recommendation)
    (5) Way less stress on the cooling system and so much less chance of blowing a hose, radiator etc
    On an episode of Wheeler Dealer (Episode with TR6) it was converted to Evans and Ed removed the rad cap on the hot engine with no ill effects
    Ferrari conversion to Evans:
    Jay Leno's recommendation:
    Disadvantages:
    (1) With Thermostat gone warmups will be longer (affects folks like me in cooler/colder regions)
    (2) Due to its higher density & viscosity the water pump may not develop the head or flowrate that it would normally. Problem??
    (3) Its specific heat capacity is about 65% that of pure water, so it's going to be less efficient at removing heat from the engine.
    That's why engines with marginal (and sometimes even with upgraded systems ) cooling systems tend to run hotter with it.
    Damn!
    janmante likes this.
  24. hessank
    hessank Formula 3
    1,747
    Canada, Florida
    Fred
    Many or most of the cars at the Peterson Museum Vault, specifically the GT40 are filled with Evans.
  25. tazandjan
    38,082
    Probably more because of corrosion fears than overheating fears. The big deal on Evans, as mentioned, is that it just does not have the heat capacity of a 50/50 ethylene glycol and water coolant mixture. System should really be designed to run on it from the beginning and not retrofitted.
    flash32 and hessank like this.
