Coolant system flush | FerrariChat
Discussion in '348/355' started by morgone, Mar 25, 2012.
  1. morgone
    morgone Rookie
    Dec 20, 2011
    13
    Arlington,WA
    James D Morgan
    Please recommend the best method for flushing the 348TS.
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,586
    San Carlos, CA
    Mitchell Le
    Jack car up and remove under trays
    Unscrew the system radiator cap
    Unscrew drains under the radiators on both sides.
    Unscrew one of the block drain (you will get a shower of poison coolant)
    Now clean up the floor and yourself so you don't slide around or fall on your arse
    Put back the radiator drains and block drain plugs.
    Put back undertray and lower car
    refill with 1:1 coolant and distilled water until it is full.
    Turn engine over with heater on full blast, and let car warm up to operating temp.
    There are 2 bleed screws on the right side of the car, toward the front of the engine compartment. You need to loosen those and wait for the air to come out until there is no air. Tighten bleed screws and you are done.
    Turn off engine.
  3. PT 328
    PT 328 F1 Rookie
    4,008
    For additional info see my reply to your thread in the technical section.
