coolant tank 360 | FerrariChat
coolant tank 360
Discussion in '360/430' started by addie, Apr 14, 2013.
  1. addie
    addie Rookie
    Dec 9, 2011
    31
    hello guys,sometimes not every time when i used my 360 there is a litlle coolant leaking from the hose of my coolant tank.Temp is normal and its just a litlle so now and then.Any suggestions what it can be?thanks in advance.
  2. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    Are you talking about the overflow pipe? Is it leaving a little puddle under the car near the cat on the 5~8 bank? Or is it leaking up at the tank?
    If under the car as described the tank might be over filled slightly. Correct is 4cm below the neck when cold but mine is quite inclined to purge down to 5cm so I generally don't fill above that level. You could also have a faulty cap which doesn't hold the correct pressure.
    If leaking up at the tank you probably just need to tighten the clamps.
  3. addie
    addie Rookie
    Dec 9, 2011
    31
    its the overflow.think my cap needs to be replaced,the top of it is also a little leaking.
  4. netman
    netman Formula 3
    Jun 17, 2008
    1,905
    OC SoCal
    I had the same issue. Finding a bit of coolant around the base of the reservoir cap. Replacing the cap took care of my issue.
  5. addie
    addie Rookie
    Dec 9, 2011
    31
    thanks,ordered a new one at ricambi.
