Hey Guys Where does the pipe from the radiator cap go to? While reinstalling the cover, the pipe came loose and I am not sure what to connect it to... Its the pipe with one end in the center of the radiator/coolant tank cap between the two cylinder heads (above the valley)... Or is it an overflow pipe (hangs down to ground to allow excess coolant to flow out)?? Thanks
Yes its just an over flow pipe. Straight to ground. Its called an expansion tank by the way, the radiators are at the sides without caps. But you knew that
I SHOULD know that (given Ive read the owners manual and service manual quite a bit)... Ah well... always a chance to learn!! Thanks shado!
