Coolant | FerrariChat
Coolant
Discussion in '308/328' started by Strike328, Mar 2, 2010.
  1. Strike328
    Strike328 Rookie
    Mar 12, 2007
    25
    Heiloo,Netherlands
    Richard
    Hi,
    Especially on the right hand rear ( 328 GTS) there is a coolant leakage when the engine is warm. After partly disassembling it, it looks like it is coming from BEHIND the waterpump...?! Does this mean the pump just went south?
    Regards,
    Richard
  2. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,324
    Could be - could be one of the two hoses under the plenum - hard to tell from the description.
    When my WP went it was throwing water out the front.
  3. PT 328
    PT 328 F1 Rookie
    4,008
    I had the issue you are describing when my water pump bit the dust.
    Unfortunately it was on the way out of town for a long weekend with my wife. Approximately 60 miles from home I noticed some steam/smoke from the engine bay. Had to have it towed home, switch cars and resume our trip. My wife was not happy to say the least.
  4. fgcfire8
    fgcfire8 Formula Junior
    Jan 19, 2008
    459
    Montpelier Va
    Frank Castelvecchi
    Are wives ever happy with the red headed pants on fire mistress?
  5. Strike328
    Strike328 Rookie
    Mar 12, 2007
    25
    Heiloo,Netherlands
    Richard
    Thanks for all the quick replies!
    I checked the hoses ( sleeves ) this morning and it looks like the water pump went bust....
    Well, at least I know what to do during my upcoming holiday.
    Regards,
    Richard
  6. bill brooks
    bill brooks F1 Veteran
    6,050
    waynesburg,pa
    bill brooks
    what about the o-ring which seals the block to the wp?
    could it have failed?
  7. Strike328
    Strike328 Rookie
    Mar 12, 2007
    25
    Heiloo,Netherlands
    Richard
    I'll let you know when I have the time and the water pump arrives.... ( it will be about two weeks) Thanks for the heads up anyway.
    Richard
  8. Strike328
    Strike328 Rookie
    Mar 12, 2007
    25
    Heiloo,Netherlands
    Richard
    ajajaj, after two days of hard work and rebuilding an as good as new waterpump.....
    indeed, the o-ring was the cause of the leakage....
    At least the coolant is replaced and the waterpump should be fine for years....
    Thanks for all the hints!
    Regards,
    Richard
  9. bill brooks
    6,050
    waynesburg,pa
    bill brooks
    glad to hear it was just the o-ring.
    as fastradio once suggested, keep an eye on the 2 weep holes on the underside
    of the w.p. housing. once dribbles are noticed, time for rebuild or replace.
