Cooling fan | FerrariChat
Cooling fan
Discussion in '308/328' started by John Clark, Aug 2, 2018.
  1. John Clark
    John Clark Rookie
    Aug 2, 2018
    4
    John Clark
    When the ignition is switched on, one of the cooling fans, only one, switches on, irrespective of the temperature of the water in the radiator. I am sure this is a recent phenomenon.
    Has anyone experienced the same "problem?"
  2. samsaprunoff
    samsaprunoff F1 Rookie
    4,465
    Edmonton, AB Canada
    Sam Saprunoff
    Good day John,
    I may be wrong on this, but I think if the AC is on then one of the fans is automatically turned on. You would need to check the 308 wiring diagram to see if this is the case... however, it could explain your issue.
    Cheers,
    Sam
  3. John Clark
    John Clark Rookie
    Aug 2, 2018
    4
    John Clark
    Thank you for the speedy response Sam. I'll certainly check it out and see if you're right. Let's hope so!
    Regards
  4. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,222
    Gold Coast, Aust.
    Patrick
    That's correct, Sam. Simple first step is to check the AC fan switch is turned off
  5. John Clark
    John Clark Rookie
    Aug 2, 2018
    4
    John Clark
    I feel rather foolish. As the model is a GTS and I always drive with the roof removed, I never use the AC. I was therefore totally unaware that I have been driving with the AC fan switched on.
    Thank you gentlemen!
