Cooling fans not turning on. | FerrariChat
Discussion in '456/550/575' started by dencap, Aug 6, 2018.
  1. dencap
    dencap Karting
    Sep 29, 2013
    127
    SF Bay Area, CA
    Dennis Caponigro
    Looking for someone in the San Francisco Bay area that can trouble shoot and repair the cooling fans on my 1999 456M.
    I checked thermal switch, swapped relays, and fuses, all OK.
    i checked the fans with direct 12 volt feed, and both fans work properly.
    Thanks for any help provided.
    Dennis
  2. centerfireman
    centerfireman Formula Junior
    486
    Roseville, CA
    I have had my 550 serviced at SF Motorsports (in San Rafael) for the last three years and have been very happy with their service. Doug, Jesse, et al, have been great to work with.
  3. dencap
    dencap Karting
    Sep 29, 2013
    127
    SF Bay Area, CA
    Dennis Caponigro
    Thanks for the recommendation.
    Regards
    Dennis
  4. Jan456
    Jan456 Karting
    Oct 1, 2008
    145
    the Netherlands
    Jan Scholte
    I had the same problem for a while with my 456M. Root cause was a too low pressure in the AC system.
    regards, Jan
  5. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,696
    Oslo
    Erik
    There is a separate ecu for the radiator cooling fans... might fail aswell.
  6. dencap
    dencap Karting
    Sep 29, 2013
    127
    SF Bay Area, CA
    Dennis Caponigro
    F456M
    Do you know where it is located? I thought the fan control was embedded in the main ECU.
    Thanks for any information you can provide
    Dennis
  7. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,696
    Oslo
    Erik
  8. tazandjan
    39,174
    There should be two signals to start the fans, one for normal temperatures and another back-up at higher temps if the first is inop. Neither working is not a good sign
