Cooling Idea
Discussion in 'Technical Q&A' started by msark, Aug 12, 2017.
  1. ATTENTION: http/https Bug Fix! Most of us have been experiencing problems staying logged in as we navigate the site. That is simply the result of links varying between http and https, which each require different logons. To resolve we are going to force https starting sometime Wednesday. However, you may have problems accessing FerrariChat until after you log out, clear cookies/browser cache, and log back on. Keep in mind my email is admin@ferrarichat.com if you do have access problems after Wednesday. Thanks!
  1. msark
    msark Rookie
    31
    Southern California
    I have successfully use Royal Purple Purple Ice and Water Wetter by Redline in other cars where the coolant temps creeped up in traffic.... Not a miracle cure but typically have been good for a 10f reduction.... Thoughts on using them in a 456M ?
  2. eulk328
    eulk328 F1 Rookie
    2,698
    F683
    Not unusual to "creep up" in traffic for any car, although you didn't define "creep up." If it's going above what it should be get your cooling system troubleshot and repaired.
