Cooling Ideas | FerrariChat
Cooling Ideas
Discussion in '456/550/575' started by msark, Aug 12, 2017.
  1. msark
    msark Formula Junior
    Feb 18, 2017
    284
    Southern California
    I have successfully use Royal Purple Purple Ice and Water Wetter by Redline in other cars where the coolant temps creeped up in traffic.... Not a miracle cure but typically have been good for a 10f reduction.... Thoughts on using them in a 456M ?
  2. Cribbj
    Cribbj Formula 3
    Just be careful which coolant you mix them with. Google "Water Wetter Brown Slime".
  3. 166&456
    166&456 Formula 3
    Jul 13, 2010
    1,723
    Amsterdam
    #3 166&456, Aug 13, 2017
    It seems to me at first that such solutions have only two applications, in situations where hot spots in an engine are a problem (racing) and as patchwork for masking other problems / postponing solutions. The problem is, the cooling system was designed to work with normal coolant. If it doesn't, something is wrong and you're not going to solve it using different coolant. Yes plain water etc can reduce temps and conduct more heat away from the engine - but something is still not right. If a cooling system has become so critical you have to revert to these kind of things, imho you need to solve the problem which is most likely a clogged radiator (in- or externally!), and collapsed steam hoses.
    Running plain water with an anti corrosion package for better heat transfer is what this discussion is mostly about. That does seem to have benefits in heat challenged engines - I'd be very wary about anti corrosion properties and freeze risk as drawbacks though.
    That said there was someone on this forum who had a piston liner that corroded to the point of being holed(!) due to cavitation, likely because of hotspotting but possibly the use of bad fuel (detonation can cause this too, it is a problem far more commonly seen in diesels). Perhaps it would have been avoided with this. Never say never.
  4. Vereeken
    Vereeken Formula Junior
    May 16, 2014
    264
    Belgium
    I would stay away.
    The car needs Glysantin. Harder to come by these days but worth the search.
    If this would be me I would start by flushing the system once with plain water. Filling up with 50/50 antifreeze. Keep it in for about 500 km and flush again, then finally fill with Glysantin.
    In the end you should have a funky yellow coolant. If it still runs hot, time to get the radiator out.
