Cooling system bleeding issue | FerrariChat
Discussion in '308/328' started by Dr Kananga, Aug 1, 2011.
  1. Dr Kananga
    Dr Kananga Formula 3
    Apr 20, 2011
    1,222
    Los Angeles, CA
    Buonapart I. Gallia
    #1 Dr Kananga, Aug 1, 2011
  2. Jdubbya
    Jdubbya The $10 Trillion Man
    43,242
    PNW
    Hmm never seen that. I have the bleed screw there. Looks like maybe someone replaced it at some point.
    I think you can still do a pretty good job of bleeding without it but obviously it would be better if it were there. I wonder if raising the front of the car so the bleed screw on the radiator is higher than the thermostat would help. Probably not as good, but might help.
  3. GT4 Joe
    GT4 Joe Formula Junior
    Oct 19, 2010
    835
    Dana Point, Ca.
    Joe Williams
    My '75 doesn't have it either. Bleed at the radiator is all you can do. I haven't had any problems not being able to bleed at the thermo neck, though....
  4. Jdubbya
    43,242
    PNW
    I didn't think to ask what year. I see now that Buonapart's is a '74 so maybe the bleed screw was a later addition to the housings?
  5. SteveG75
    SteveG75 Formula Junior
    Nov 23, 2010
    380
    FL
    Stephen
    No thermostat bleed screw on my '77. Just bleed at radiator, never had a problem.
  6. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    Same here and never had a problem.
  7. shawxhurst
    shawxhurst Formula Junior
    Nov 6, 2006
    672
    San Diego
    Steve Hawxhurst
    Remember, the initial bleed is with the engine off and the expansion tank cap off. If the front is much higher than the rear the coolant will just overflow the tank and end up on the driveway. I'd rather not discuss how I know this.
  8. chairpilot
    chairpilot Formula 3
    Mar 3, 2007
    1,547
    LA, CA & Olympia, WA
    PlateClipGuys
    Make your own bleeder. What would be so bad about drilling and tapping a hole there? I'd expect the wall thickness to be about 1/8"+......enough to drill and tap in a 1/8" brass pipe threaded plug, which would catch about 3-4 threads. Of course I'd recommend draining down the coolant a few inches, pull off the upper hose and stuff a rag inside to catch the shavings. Have a shop vac standing by too!
    Bob
  9. Steve Magnusson
    26,846
    #9 Steve Magnusson, Aug 1, 2011
    Another option is to just (greatly) loosen the hose clamp and then insert a small screw driver, or similar item, between the (unclamped) hose and the housing and over the "ridge" on the housing nipple (just be careful to not damage the ID surface of the hose). This will (temporarily) open an intentional "leak" path between the hose ID and housing nipple OD for bleeding.
  10. Fave
    Fave F1 Rookie
    Aug 12, 2010
    4,157
    Tarana
    L. Ike Hunt
    Is there not a bleed screw on the 1-4 side of the block ?
  11. BigTex
    79,386
    Houston, Texas
    Bubba
    Yes, WAY later in the life cycle of the 308, 1983 or so.
    The early cars bleed only at the radiator.
  12. chairpilot
    Mar 3, 2007
    1,547
    PlateClipGuys
    My '83 does have the top bleeder. I also modified my brass plug by drilling the double holes (like Verell's) so I do not have to remove it completely to do the bleeding procedure. WAY EASIER and less messy.
  13. BigTex
    79,386
    Houston, Texas
    Bubba
    Just a guess on the year....I have no idea, but there's nothing "missing" off a 308GT4 without one...LOL!
  14. Jdubbya
    43,242
    PNW
    My '78 GTS has the bleed screw so maybe mine is not original. Who knows with these cars!!
  15. Steve Magnusson
    26,846
    The US SPC illustrations shows that the bleed screw on the thermostat housing was introduced in MY 1978 (but, like wheels, they could be swapped between years after leaving the factory ;)).
  16. chairpilot
    Mar 3, 2007
    1,547
    PlateClipGuys
    That is too low to function as an air bleed Fave. It's only to assist draining the block. I use it to quickly lower the level some minor amount when I need to disconnect any upper hose connections without dumping the whole system.
  17. Dr Kananga
    Apr 20, 2011
    1,222
    Los Angeles, CA
    Buonapart I. Gallia
    Trade secrets.
  18. Dr Kananga
    Apr 20, 2011
    1,222
    Los Angeles, CA
    Buonapart I. Gallia
    So much to discuss when we link up :)
  19. shawxhurst
    Nov 6, 2006
    672
    San Diego
    Steve Hawxhurst
    I believe there was a post in the past few years from a guy who invented a bleed screw that had a nipple on it like a brake bleed screw. You could clamp a hose to it and send the excess coolant to a container rather than just the bottom of the car. I have the Verell screw and I have to stuff a rag or towell around the housing to catch as much as possible. This guy's piece was really trick.
  20. chairpilot
    Mar 3, 2007
    1,547
    PlateClipGuys
    That sounds even better. But, it won't look "stock" (LOL!)
  21. Peter
    Peter F1 Veteran
    Dec 21, 2000
    6,440
    B.C., Canada
    #21 Peter, Aug 4, 2011
  22. shawxhurst
    Nov 6, 2006
    672
    San Diego
    Steve Hawxhurst
    True. I wonder how many concours judges would catch it. Is the OP planning to show at Pebble Beach in the near future?
  23. Dr Kananga
    Apr 20, 2011
    1,222
    Los Angeles, CA
    Buonapart I. Gallia
    This is great!!
  24. ME308
    ME308 Formula 3
    Nov 5, 2003
    1,550
    Munich, Germany
    Michael
    Peter to the rescue... of all nippleless t.stat housings ;)
    nice solution !
  25. Peter
    Peter F1 Veteran
    Dec 21, 2000
    6,440
    B.C., Canada
