Copper braid negative ground Part #115667 - weak Achilles? | FerrariChat
Discussion in '308/328' started by Du_Man, Jun 19, 2020.
  1. Du_Man
    Du_Man Formula Junior
    320
    Dallas, Texas
    Derek
    So I am peeling back the front end of SN32001 to expose the inwards/frame(rust?) and diagnose what needs to be repaired or replaced. I get curious by the battery (-) cable and follow it to this quick disconnect/copper braid part.
    I have never seen this on Fchat. This looks like an inadequate "ground" from the battery to the frame. The braid looks fragile and not the best for conductivity/grounding. WTH - I want to run a 2 or 4 gauge cable to the frame. Am I wrong? I see the stories of the senior 308 having grounding issues.
  2. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,898
    Mike 996
    Actually a braided cable like that for the ground has far more conductive area than a 2 or 4 gauge cable. It is also more flexible and less likely to pull loose from a connector.
    waymar likes this.
  3. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    All the grounding issues I've ever run across were due to conventional cable and connections, never the braids.
    waymar and Saabguy like this.
  4. Du_Man
    320
    Dallas, Texas
    Derek
    I learned something today...thank you.
  5. mwr4440
    58,013
    Bavaria, The 'Other' Germany
    Mark W.R.
    I unbolted it from the frame.
    Lots of club in the contact area.
    Cleaned it up and bolted it back in.
    Did it help?
    Probably, but ... who knows.
    Sure Didn't HURT.
    Du_Man likes this.
