Corosion on water hose connection | FerrariChat
Discussion in '308/328' started by Zenobie, Oct 14, 2024.
  1. Zenobie
    Zenobie Formula Junior
    Feb 22, 2021
    251
    Belgium
    CO
  2. Portofino
    Portofino Formula Junior
    Sep 17, 2011
    863
    Yorkshire UK / Switzerland/ Antibes France
    Portofino
    Yup that’s the spigot .
    Bet it’s rotten under that hose .
    https://www.ferrarichat.com/forum/threads/heater-hose-spigot.686582/
    Goes fwds as you say to heater box at the front scuttle and if I recal re enters with special T pieced pipe very close to the bottom rad hose under the spare wheels tub . Water returns with the main return rad hose .
    Zenobie likes this.
  3. mixedgas
    mixedgas Formula Junior
    267
    Ramona, CA
    There are 4 rubber hoses running front to rear in the sills. Two on the left side (coolant hose to heater, and vacuum hose to brake booster). Two on the right side (both are for air conditioning).
    Zenobie likes this.
  4. Zenobie
    Feb 22, 2021
    251
    Belgium
    CO
    Is work for next week, for the time being i have not enough jerry cans to collect the antifreeze, I will only let off the antifreeze to just below the level of the spigot.
    Where is the best drainpoint to do this?
    Up to this point there has been no dripping at the connection and hope the spigot is fine/stil usable.
  5. Freddie328
    Freddie328 Formula Junior
    Jul 29, 2013
    389
    Herts, UK
    Richard
    Underneath the front of the car the heater hose tee's into the radiator pipe. You will need to remove the front inspection plate to access this tee. Remove the heater pipe at this point. This will drain most of the fluid from the cooling system.
    mixedgas and Zenobie like this.
  6. Imatk
    Imatk Formula Junior
    May 6, 2007
    769
    Do yourself a favor and buy one of these.
    https://clarkandclarkinc.com/catalog/detail/front-coolant-drain-valve-kit-for-308328
    You have to run the hose anyway so might as well make life easier for your to service the coolant later.
    To completely get all of the coolant you'll need to drain the block as well.
    I don't know if you feel that's necessary or not... depends on if your coolant has been flushed.
    If it was me (and it was just a few months ago) I would replace every single rubber piece in that system (including the ones under the front hood), remove the metal coolant pipes and clean them and inspect for any damage and completely flush the coolant since it's probably got lots of sediment in it from the old decaying hoses.
    For the block there is another drain valve on the rear just near the exhaust. If yours has never been opened it might be impossible to open it... mine was and you'll have to replace that as well. Fortunately for me when the car's valves were being done and the head work was being done the shop did that piece of work for me.
    Milkshaker0007 and Zenobie like this.
  7. Zenobie
    Feb 22, 2021
    251
    Belgium
    CO
    Indeed , good option. Thanks
    Imatk likes this.
  8. Zenobie
    Feb 22, 2021
    251
    Belgium
    CO
    #8 Zenobie, Oct 16, 2024
    @Freddie328,
    Strange my 328 - 1986 Europe version is not like that there is a water tube left and right ( no T on both of them) not the 2 at the same side but there is a draining point on the radiator on the left driver side.
    One should think ho much easer hmmm "close but no sigar" The form of the bumper unhtherneat the radiator is not horizontal and there is no evacuation hole in the bumper, so had to make a kind of form/mold and a small hole in the bumper So now the anti freese is directed to the hole and can drip directly in to a container. So..............now its easy :) or maybe not it always remains a Ferrari :)
    After the works are finished i will poste a picture
    @Imatk, so your verry good suggestion is no option ( for me) anymore as there is no possibility to do so
    Imatk likes this.
  9. Rifledriver
    37,106
    When the hose is that bad the fitting in the head is usually very rotten too. I have installed dozens of brass 5/8 inch hose barbs in their place. If you get one with 3/8 NPT threads its slightly oversized and you can just drill out the original, run a NPT tap into the hole and install a new barb. All can be done in the car.
    Same can be done with the small hose barb on the coolant manifold under the plenum chamber.
    dflett, Imatk, mixedgas and 1 other person like this.
  10. Zenobie
    Feb 22, 2021
    251
    Belgium
    CO
  11. bitsobrits
    bitsobrits Formula Junior
    Nov 12, 2011
    747
    Omaha, NE area, US
    Steve
    ACF 50 can't hurt. But what does the inside of the hose barb look like?
    Zenobie likes this.
  12. mixedgas
    267
    Ramona, CA
    looks pretty lucky to me
    Rifledriver and Zenobie like this.
  13. Zenobie
    Feb 22, 2021
    251
    Belgium
    CO
    The inside of the barb seems to be smooth, the hose is stil flexible and on the inside no cracks and no contamination after a few cm.
    It looks as the hose was initialy damaged by a to thigt hose clamp
  14. Rifledriver
    37,106
    Its called antifreeze service. No more prevention than that.
    bertrand328, lm2504me and Zenobie like this.
  15. Zenobie
    Feb 22, 2021
    251
    Belgium
    CO
    OK next question.
    Does the system bleed itself or are there bleed screws somewhere?
    I haven't started it yet, but some cars such as my Lancia Montecarlo (also rear engine) bleed better when the rear is raised?
  16. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,811
    Cerritos, CA.
    The bleeder screw is on the upper right corner of the radiator.
    Zenobie likes this.
  17. Freddie328
    Jul 29, 2013
    389
    Herts, UK
    Richard
    There's a bleed screw on top[ of the thermostat housing. Have it open when you fill the system. I've never found any need to open the rad bleed screw. With the pump primed by opening the thermostat bleed screw, the system then self bleeds. There is a lot of bypass back to the header tank which supports this.
    Zenobie likes this.
  18. Portofino
    Sep 17, 2011
    863
    Portofino
    Takes a few goes with the fwd rad bleed screw . I park it up a hill 2/3 times and let the air out of the rad when its warmed up
    Expansion tank should be approx 1/2 to 2/3 rds full when it finally all settled .
    Run it with the heater full on while you are burping it to get trapped air out of the heater core .
    Zenobie likes this.
  19. Rifledriver
    37,106
    When the factory filled them they did it 100% successfully on a flat floor, open both bleeders, fill until both overflow and you are done.
    No further action required until next coolant change.
  20. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,574
    San Carlos, CA
    Mitchell Le
    Or, get yourself an Airlift (tm) .
    lm2504me likes this.
  21. Zenobie
    Feb 22, 2021
    251
    Belgium
    CO
  22. Zenobie
    Feb 22, 2021
    251
    Belgium
    CO
    I don't understand it.
    As mentioned in another thread I replaced the injectors because the engine held back and did not run on 8 cylinders for a while between 2000 and 3000 rpm.
    Now the replacement did not improve but when I turned off the engine I heard a bubbling in the expansion tank.
    So I bled the radiator and thermostat housing again......at least for the 4th time and again a lot of air came out. Short ride with hot engine and again a lot of air came out......Again short drive same story.
    I have done this to this practical all my previus cars (+/- 45) never had any problem
    Antifreeze in expansion tank is at the correct level and I have no water leaks anywhere so what am I doing wrong or what else can I do?
  23. moysiuan
    moysiuan F1 Rookie
    4,190
    Canada
    Put some Hylomar Blue on the barb. It will help seal with a bit less less clamp force avoiding hose damage, and will act as a corrosion barrier. It is a non hardening urethane based compound and the hose can still be removed easily in the future.
    Zenobie likes this.
  24. Rifledriver
    37,106
    So? System needs air to work. Is it running hot or boiling over? Is coolant coming out. If air is going in, something must be coming out.
    You can bleed it till the cows come home on a perfect functioning system. It needs air.
    Zenobie likes this.
