correct back up and license lights for sept 1970 246 | FerrariChat
Discussion in '206/246' started by euro70, Jan 12, 2007.
  1. euro70
    euro70 Rookie
    Dec 9, 2006
    23
    i would like ino on 246's in the range of 1060....i have photos from a 1969 as well as a late 206 related to type of backups and license lights...research info indicates that L series have backups under bumper...and license lights at end of bumper....the license lights i have seen on cars earlier than mine have solid ends to the bumper and screw mounted housings with the reflector type m bulb...my bumper has a separate closure cap that follows the bumper profile and with a recessed shape [not flush as i have seen on other dinos], but no housing for light...??? any 1970 dino photos of original cars or concour judges with accurate info...or owners with cars around this produstion time frame...thanks in advance for data...frank
  2. rwk360
    rwk360 Formula Junior
    Aug 26, 2005
    394
    Pebble Beach, CA
    R W Kenton
    Welcome! I have a 69 (obviously) L-series, and my license lights/inboard bumper ends are exactly as you describe yours to be. Under-the-bumper backup lights are also correct for L-series; wish I still had mine- they were lost during bumper replating 3 years ago. If anybody reading this has a lead on the location of a pair, please PM me; they appear to made of unobtainium.
  3. 4redno
    4redno Formula 3
    Mar 21, 2006
    1,067
    Seattle, WA
    Keith Mitchell Wintraub
    #3 4redno, Jan 12, 2007
  4. 4redno
    4redno Formula 3
    Mar 21, 2006
    1,067
    Seattle, WA
    Carello reverse lights were pretty common. The same lights were also used in various places on Alfas, Maseratis, Lambos and probably other Italian cars. Dennis McCann lists the complete assemblies including lenses and rubber for $225 each. There is a different lamp for the left and right sides respectively on an L series car.
    The same can be said of Carello license plate lights. I've found them at swap meets in the past (often referred to as Carello frogeyes) and I think good repops are available too.
    Seek and ye shall buy.
    ...Keith
  5. dm_n_stuff
    Dec 10, 2003
    43,747
    26.806311,-81.755805
    Dave M.
    same as late 60's alfa spyder, I think.
    Try international Auto. www.international-auto.com, probably need to call them, their website can be a little unweildy when you're trying to cross reference ferrari with alfa parts.
    DM
  6. tx246
    tx246 F1 Veteran
    6,663
    Texas
    Shawn
    as much as i am a fan of original design, these lights look silly. yes, i have seen them before, but i think the transition to the later style has a better asthetic appeal. given that, i can't say the same for the other subtle changes in the l series dino's. i wish the e series had the knock off wheels, they definitley have a more pure look than the caps and bolts.
  7. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    The later style license plate lights were mounted in a chrome housing that was attached on the vertical edge of the rear trunk. The power wire to these lights went through a chrome "butt contact" connector on the rear batchboard. This connector is a simple, double flange with a cylindrical cutout in the center for the spring loaded contact. The flange ears typically break off and the connection no longer works, hence the license plate lights do not illuminate.
    Has anyone seen replacements?
  8. celestialcoop
    celestialcoop Formula Junior
    715
    Coop
    Have y'all seen the pair of license plate lights on eBay with minimum bid of $180? No action yet. Auction closes in less than 5.5 hours.
    eBayEbhttp://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=260073433366&fromMakeTrack=true
  9. 4redno
    4redno Formula 3
    Mar 21, 2006
    1,067
    Seattle, WA
    Yep! Those are the Carello license plate lights. $180 final bid is quite reasonable.
  10. celestialcoop
    715
    Coop
    Frank,
    I take it that you have the push button release for your deck lid, and that you don't have any license plate illumination now. You might trace your car's wiring to see if the leads have been cut or tucked away. You'll likely need 'em at some point in time.
    At any rate, those Carello lights that I referred to previously did not sell and have been relisted with the same $180 opening bid.
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=260076650176&ssPageName=ADME:B:WNARL:MT:12
    You might consider bidding on them. Getting those would be a step in the right direction. As for the original end caps like Keith's & Robert's (any ideas, gents?), I dunno.
    Good luck & keep us posted.
    Cheers,
    Coop
  11. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    So was this winner actually a shill? LSR style?
  12. euro70
    euro70 Rookie
    Dec 9, 2006
    23
    ....thanks for info checked ebay listung ,,those are them...but in the meantime bought from lyle tanner...same price as staring bid....also lyle had the oem under bumper lights as well...yes my wires had been cut and redirested to a center backup typlical of later models..thanks for help ...
  13. celestialcoop
    715
    Coop
    Scott,
    'interesting supposition. I hadn't noticed that they had 'sold' the first time around. Since I had them on my watch list, eBay automatically sent an email advising that the seller had "relisted" them. Hmmm. Buyer (Bidder) Beware!
    Frank,
    'glad you located the new parts at Tanner's & didn't bid on the used ones. This is a good reminder that it pays to check the usual sources for new items before getting too wrapped up with eBay.
    Did Lyle T. also have the bumper end caps? If not, do you have a lead?
    Have fun getting it back together...it would be great to see the end result.
    Robert,
    There ya go. You were asking about back up light availability: Lyle Tanner.
  14. euro70
    euro70 Rookie
    Dec 9, 2006
    23
    related to the bumpers....from keiths photos and the 206 at my friends restoration shop (serious ferrari restorer guy)these bumoers have a flared section at the ends that are not a separate piece of metal....they are integral to the bumoer and act as an end closure to the hard rubber trim.....seems the bumpers on my car may have been changed????so the only way to achieve corrctness is either new bumpers or my restorer takes out some steel fires up the welder to achieve correct shape to match the 206 in his shop ....rechrome and move on to next details....commentary welcomed......
  15. euro70
    euro70 Rookie
    Dec 9, 2006
    23
    keith after further study....i can't see the end detail of your bumper at the rear quarter on the side of your car....the 206 i saw has a flaored stop similar the the rear to stop the hard rubber trim.....is this what yours has ...also does your hard rubber trim tuck into the end closure or is it a end butt condition.....thanks ..frank
  16. 4redno
    4redno Formula 3
    Mar 21, 2006
    1,067
    Seattle, WA
    #16 4redno, Jan 18, 2007
    Frank:
    It's true; my bumpers have that integral flare. I've attached two additional photos for your reference.
    At some point (perhaps at chassis 01250 when they shortened the front bumpers so that the no longer turned into the grill) they also got rid of the flares. The newer bumpers also use a different shaped rubber that slips over a T-shaped ridge when mounted. Early cars like ours used a smaller profile rubber which contains a channel into which a long metal strip is inserted. The rubber is then slipped into the groove, tucked in the flared ends and screwed into from behind. The metal screws grip the thin metal strips in the bumper rubber and pull them tight to the bumpers.
    When I restored my car, I had a couple of bumpers which needed "work". Adding a flare and resizing a groove or two is something which I had done by Butch Dennison in the Pacific Northwest and the results were great. Queen City Plating did the bright work and it still looks brand new. Have no fear because time, money and craftsmanship can make them perfect.
    ...Keith
  17. euro70
    euro70 Rookie
    Dec 9, 2006
    23
    again thanks for photo...exactly like the 206 i have seen and made a dimensional sketch for....you are correct about the time/money situation,,,but this is what i expected the situation would be ...and i am ok with the value of each little effort...and sucess....great description on install process and rubber trim...i assignment is now clear...regards frank
  18. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Are these on Ebay the same ones?
    http://cgi.ebay.com/ebaymotors/USED-ORIG-FERRARI-DINO-246-EARLY-PLATE-LIGHTS_W0QQitemZ140093216832QQcategoryZ140741QQrdZ1QQcmdZViewItem
  19. GTA246GT
    GTA246GT Karting
    Oct 23, 2005
    79
    Sweden
    #19 GTA246GT, Mar 12, 2007
