Correct carb jetting for 206? | FerrariChat
Discussion in '206/246' started by DinoFiat, Aug 6, 2014.
  1. DinoFiat
    DinoFiat Rookie
    Mar 27, 2008
    25
    North East USA
    Fred F
    Hey Guys,
    I'm finishing up the restoration on my Fiat Dino spider 2.0 and I'm trying to find out the correct jetting setup on the carbs. Everything I can find gives me the specs on the 2.4 engine but I can not find anything for the 2L. I would think with the smaller displacement there would be a difference. Anyone know??
    Thanks in advance.
  2. rosso corsa motorsport
    rosso corsa motorsport Formula Junior
    Nov 30, 2008
    268
    post a pic on your carbs and i tell you
  3. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,638
    Toronto / SoCal
    Rob C.
    Bear in mind that the original jet sizes published 40 years ago will act as a starting point but will be wrong for the fuels available today. For optimum performance the jets will need to be adjusted which can only be done properly with on car tuning.
    JCR likes this.
  4. rosso corsa motorsport
    Nov 30, 2008
    268
    those are the late type Fiat Dino carbs
    you can use the same spec as you found on Fiat Dino 2400
    the early carbs have different jetting
  5. Ribolla_67
    Ribolla_67 Karting
    Sep 6, 2016
    94
    Austria
    I just found this thread and would like to provide OEM Fiat info:
    EARLY DCN 14 for 2000 series 1:
    Main jet: 130
    Air corrector: 180
    Idle jet: 55
    Idle Air:
    Accelerator pump jet: 40
    LATER DCNF 3 for 2000 series 2:
    Main jet: 120 (125)
    Air corrector: 220
    Idle jet: 50
    Idle Air: 120
