Correct Dino Wiper Arms? | FerrariChat
Discussion in '206/246' started by 4CamGT, Dec 3, 2010.
  1. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,799
    Southern California
    #1 4CamGT, Dec 3, 2010
    All,
    I need to find the correct wiper arms for my Dino *03932*. The ones I am showing is what I think I need. These are "arman&c" from John's Dino. My Dino came with a pair of "arman&c" arms but both are straight. The drivers side on John's is bent at the top(see image). I contacted Dennis McCann without luck. Maybe someone has a used set? Would also be interested in correct blades and any advice on rebuilding the wiper motor/assembly(or who can do it) or if anyone has a lead on a correct replacement.
    Best,
    Freeman
  2. UroTrash
    Jan 20, 2004
    40,487
    Purgatory
    Clifford Gunboat
    #2 UroTrash, Dec 3, 2010
  3. patrickvela
    patrickvela Rookie
    Sep 13, 2008
    16
    Are the Blades "handed" i.e left and right side? Mine sit differently on the screen when changes around.
  4. BigTex
    79,380
    Houston, Texas
    Bubba
    #4 BigTex, Dec 5, 2010
    More accurately, the three pieces are the "arm" which are specific to the various Ferraris, the end "blade holder", made of dual wires on my 1976-77s and then the rubber insert itself...
    I've bought Ferraris with them on backwards swapped LH for RH, works 'more better' to have them on properly..
    No experience with the Dino configuration you have Freeman, good luck though!!!
    Looking at those, I'd think the flat one should be closing to the lower position, with the other 'bent' one with the offset snuggling on top.......but you really have to watch them as they park, to see how they merge.
  5. BigTex
    79,380
    Houston, Texas
    Bubba
    Yes.......(see answer above).....definately.
