There seems to be some confusion about the correct door light on the US Dino? The confusion stems from the fact that the European model has two lights that some use interchangeably but should not! Part # 20083507 side repeater and Part # 200836 rear door light. The main difference is the side repeater has a chrome ring while the door light does not, hence the two different part numbers. If one goes on the Maranello Concessionaires website you will see the difference. As an original Dino owner, I do not remember a chrome ring on the door lights! FYI
