correct gas?? | FerrariChat
correct gas??
Discussion in '308/328' started by gtbman, Apr 21, 2010.
  1. gtbman
    gtbman Karting
    Sep 28, 2009
    69
    is 93 octane acceptable/optimal for a 1987 328 ??
  2. Steve Magnusson
    26,826
    #2 Steve Magnusson, Apr 21, 2010
    You have to clarify what version 328 (euro or US), and whether you are talking about 93 AKI (the octane rating used on the pumps in the US) or 93 RON.
    The manufacturer's specs in the 328 OMs are:
    US 328 = 95 RON minimum = about 90 AKI minimum
    euro 328 = 98 RON minimum = about 93 AKI minimum
    93 AKI would be "acceptable" for a US 328, but you would be overpaying for something that you don't need (and might reduce power a smidge).
  3. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,786
    Marin
    Geno
    While on the subject, how about the best gas for a carbed US spec 308? I heard that using anything other than 87 octane is a waste bc the engine cant take advantage of it.
  4. Steve Magnusson
    26,826
    #4 Steve Magnusson, Apr 21, 2010
    Certainly true for a '78-'79 US version 308 that only has a 91 RON minimum fuel spec (about 86 AKI minimum). The '73-'77 US 308 might have a higher spec (I've no data), but it was also from a time when available fuel octane was generally higher so the manufacturers weren't so fussy about trying to spec the absolute minimum octane rating needed and could error on the high side without impacting the consumer much. Also, the octane rating on the US gas pump is the minimum guaranteed AKI value -- not the exact AKI value -- so all "87 octane" is not necessarily equal (and people's experiences may vary).
  5. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,514
    Honolulu
    Kevin
    #5 Kevin Rev'n, Apr 21, 2010
  6. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,872
    Mike 996
    The winter/summer volatility change does not change the octane rating of the fuel delivered at the pump. So it does not need to be considered from the aspect of octane rating.
